Question about Cuisinart Coffee Makers & Espresso Machines
Water does not heat - Cuisinart Coffee Makers & Espresso Machines
  • 94 Answers
Depends if it is an older model .and yea hard water deposits. can slow down or plug up the tube.. if it is a new one , machine lights up etc ,but no boiling water ? then the thermal fuse inside under the plate or by the aluminum tube clap on set is burnt out..usually an 8 or 10 amperage small as a aspirin pill about $ 8.00 at radio shack ..we like the resettable instead ..but must drill a small hole in plastic body...
Posted on Mar 19, 2014
Water heater
Most instant-on tankless water heaters require at least 10 psi of water pressure to start the heating process. The flow of water determines how hot the water will be, within the heating range. An electric 110 volts heater will increase the water temperature about 25 degrees F. A gas water heater will increase the water temperature about 45 degrees F.
Too much flow will not allow the water time to heat. Too little flow will not allow the heating system to work. Each heater must have the outflow water flow adjusted for the best heating outcomes. The best way to find the ideal flow is to turn the hot water facet on and adjust it (open or close) until the water reaches the balance of producing hot water.
Apr 25, 2016 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Want to shut off my hotwater heater and still run my boilerhave base board heat
Turn off water but leave heat on - Possible? - Handyman WIRE ...
handymanwire.com > ... > Heating and Air Conditioning
Jan 14, 2003 - 10 posts
My hot water baseboard heating system is a closed system. ... Could I shut off the main water and leave the boiler and heat going for ... If one is not installed, install one and rely on that to save the boiler from the damage of running out of ... I do not wantto have city water push my antifreeze out of the system ...
What's the best temperature to set my hot water baseboard ...
greenhomeguide.com/.../whats-the-best-temperature-to-set-my-hot-water...
Nov 21, 2010 - With hot water baseboard heating, is it better to keep the heat at 60+ degrees ... a hot water heating system where water is heated in a hot water boiler and then ... by setting the thermostat to lower the heat when you don't need it on. ... Not only do I turn my heat down when I leave for work in the am but also ...
Jan 17, 2016 | Water Heaters
What material is usually used to transfer heat around central heating systems?
Water. Water is a good conductor of heat. The boiler heats the water, a pump circulates it around the system and through the radiators where it loses heat. Cooler water returns to the boiler for re-heating.
http://www.waermecenter.de/
Jun 16, 2015 | Microwave Ovens
Will well water cause a problem on the heat pump water heater
I would say yes.
Because element may not be easy to replace, or easy to reset unit after replacement
I would also suggest not buying heat pump... must be in at least 10'x10' room with 7" space around entire heater
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
Gene
Oct 15, 2014 | GEH50DEEDSC GeoSpring Hybrid Water...
On a water cooled scotsman ice machine, should the water be running out of drain line contiuously as its making ice? be cause it just runs all the damn time and thats a huge water bill ...
On a water-cooled system, by design the heat from the machine is being transferred to running water that carries the heat away. Some installations pump this "waste" water to a heat-exchanger or cooling tower (typically on a rooftop), where the heat is transferred again, this time to the air. The water with the heat removed is then recycled back to the machine, where the process is repeated continuously. There is thus no "wasted" water.
If your cooling water is just running down the drain, that's a terrible waste of water and money. Try to find a way of recycling the water by removing the heat and re-using it. Think of ways to use the "free" heat in the water.
Alternatively, buy a proper rooftop heat exchanger and pump the water through it, or, get an old car radiator or air conditioning condenser and a decent blower, and make your own.
Remember that your machine needs constant cool water in order to avoid overheating the system.
Oct 31, 2013 | Kitchen Appliances - Others
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Dishwasher not heating water
British machines are Cold water fed, and the machines heat the water themselves. American Machines are hot water fed.
Nov 05, 2007 | Dishwashers
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
