Question about Sony RM-PP411 Remote Control
My remote dont work wont turn receiver on or off
My denon 1905/785 receiver stopped working on zone 2. It has worked for years and just stopped working. It dont know if it simply doesnt work or just wont let me turn the volume up any longer using the...
Try a reset to factory defaults and reprogramming your preferences. Time consuming, but sometimes things go bung inside the microprocessor controllers.
Sep 02, 2013 | Denon AVR-1905 Receiver
PIONEER RECEIVER VSX9700S REMOTE ISSUE
check your remote. try fresh batteries as well. if it still wont work, try opening your remote and clean it with a soft bristle brush or the like. try testing it again.
Jan 27, 2008 | Pioneer VSX-D906S Receiver
Tv remote wont work the lights turns on but still wont work
There are two ends to IR control; the remote itself and a receiver inside the set that is active any time the set has AC available. Testing the receiver end requires a known-working remote control but you can check to see if the remote is still sending IR signals by taking any digital camera you have on hand, turning it on as if you wanted to take a snap of something, watch the display while you aim the working end of the remote toward the camera's lens and holding down any button on the remote. If the remote is sending IR signals, you will see these as white spots, often blinking rapidly, on your camera's LCD screen.
If the remote is outputting IR, the receiver in the TV is likely dead and will require replacement.
Jun 01, 2012 | RCA Televison & Video
I unplugged the apex dt250 digital receiver and know it wont get any signals
It might have been resetted. Try to make an auto tune function. Refer to its user manual.
Apr 22, 2012 | Televison & Video
My 3.2 IR 166173 BELL remote wont work on my bell reciver
Ensure that the TV is turned on. Turn the Bell receiver on manually (at the receiver). Remove the batteries from the remote. Press the "Power" button on the remote until no buttons on the remote light up (a half-dozen times). The satellite service (your Bell service) will likely have turned itself off in the process. Replace the batteries in the remote. The remote should now work as "normal".
Nov 26, 2010 | Televison & Video
My boyfriend hooked up my speakers in my car to my cdx-gt200, now my cd player wont even come on. He never touched any of the connection wires for the player. At first he could not find the remote turn on...
change the fuse behind the system.
"so he hooked it up to the left front speaker wire, then found the remote turn on wire and hooked it up to it." will have burned the sound system or not. remove the new installation, test it, reinstall, test again.
Jun 01, 2010 | Sony XPLOD CDX-GT200 CD Player
How do i reset my nokia d box i lost some channels so i tried to rescan but now i can't receive any channels
i catched the remote & the button for the d-box on the remote . catched it again , but dont know which i catched & it went off . tried re-booting it & the remote wont work it . no matter which button you press it wont register on the box . it works manualy , but wont work with the remote . can it be solved ? . brian
Jan 26, 2010 | Televison & Video
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
Jul 04, 2009 | Yamaha HTR-6130 Receiver
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
