Question about Cricut Expression Cutting Machine
Cutter is not moving side ways
The cutter assembly does not move side ways. I've tried to do a reset but still I got no sides movements
Plese help me t2300 error 21:13
System Error: 21:YZ
Problem Description: Failure moving Service Station
Corrective action: Try the following:
1. Switch the power off from the back of the product and disconnect the power cord. Check
the Primer Tubes. Reconnect the power cord and power on the product.
2. Make sure that the Service Station path is clear. Remove any visible obstacles (screws,
plastic parts, etc.) restricting the movement of the Service Station.
3. If the carriage has stopped over the service station, on the right side of the product, check
that the cutter is not activated. The cutter may be blocking the carriage over the service
station, preventing the service station from performing the movement correctly. The cutter
is on the left side of the carriage.
4. Perform the Service Station diagnostic test to troubleshoot the problem further. See
Service Station Test on page 102.
5. Replace the Service Station. See Service Station on pag
Mar 01, 2014 | HP Designjet T2300 Inkjet Large Format...
Bogs when blade is engaged
for this to happen you must have a bearing problem either in the gear box or cutter deck that has seized from rust or failed bearings. disconnect the cutter belts and see it t moves forward freely If so then turn each cutter spindle by hand and find which one won't turn or is rough in the movement.
Jun 09, 2013 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I can't figure out what is wrong. When I try to use the razor the cutter seems frozen and doesnt move side to side. When I take off the foil I see that the cutter seems to move perfectly fine. I then...
If you are having the same problem with both your old and new foils and cutters it sounds like there is a problem with the oscillator in the swivel frame. Sometimes the plastic oscillator inside will partially break and it can not vibrate under the load of the foil and cutters.
This swivel frame is part of the 'drive unit' and can be found available at shaveroutlet.com. See link below for item and scroll down the item page for installation video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Aug 16, 2011 | Braun 8585 Electric Shaver
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
We have an Oster 78950-100-700 model and I dont' think it worked out of the package. It seems that the head does not move. It is like the bottom blade is putting to much pressure on the top blade and so...
The two screws of the blade guide are tightened completely. Adjust the tension between the blade and the blade guide with the large plastic screw on the side of the trimmer (this allows the blade to move rapidly from side to side). I plug it in at this time and when the cutting blade begins to move the clipper makes much louder noise. This is normal but it sounds like it is broken, it isn't. Adjust the cutter slightly past movement. You don't want it to bounce on the guide
Feb 27, 2011 | Oster 78950-100
How do you change the blades on a dw734 planer
Did you save the wrenches for the blades and the setting gauges? You need them. It is hard to do without. You have to take off the dust cover, should be called the finger cover, get the cutter head to lock up, it should have a pin on the right side to lock it from turning, loosen the jib screws,(bolts), and blow out he cutter head. Leave the adj screws where they are. Then do the other side, sharpen the knives, or get the new ones ready, don't answer the fone, or eat dinner at this time. The knife setter sets each knife to the same height and/or depth across the cutter head. It is a small C shaped thing that rides on the head and grabs the tip of the knife when it is at the right depth, they all have to be the same, and they just scrape the knife, they don't pull it or move it, it just touches it. Snug up the jib screw, and move to the middle, check and adj the height snug up the screw, move to the end, do the same, go back to the other end, check it again, use a small piece of wood to tap it down if you have to move it, when it looks good, torque it down, then do the other side the same way. I hope this doesn't have those tiny 2 sided knives in it? They are the worst, they have no meat, they don't cut worth a flip. You need the big knives, something with some meat to them. Check it out, hope this helps.
Jul 17, 2010 | Dewalt Planer (DW734)
Wahl KM-SS pet shaver motor runs but cutters dont move
it seem that shunt arm that move the cutter blade is broken or off it's guide without look at it it's hard to tell what wrong, try Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers. they can help.
Mar 05, 2010 | Wahl 8892-002 Kennel Pro Clipper Kit
Andis Ag2 clipper blades-I dropped the 4fc blade and now it will not cut. How do I adjust it so it will cut?
can you move the cutter blade (this is the smaller blade) side to side easily with your fingers if so the tension on the cutter blade has loosen. you need a special tool to reset the tension and the spec' on how much tension. send the blade to mannyssharpening.com they have fast return service and return shipping is included in the sharpening price.
Jul 12, 2009 | Andis 01690 Hair Trimmer
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
UP-DR100 Error 0008 problem
Problem: The Printer does not detect the Reverse position of the cutter during initialization.
Either there is a scrap piece of paper obstructing the path of the carriage that houses the cutter blade or more than likely impact on the lower left side of the printer causing a bend in the metal that holds the Reverse switch.
This switch will trigger a sensor telling the printer that the cutter has reached the Reverse position(left side)
The grinding noise is caused by the cutter carriage rubbing on the inner side of the door panel. The door panel shifted inward and is obstructing the path of the cutter blade.
Solution:Replace the door panel and check for damage on the left side of the cutter blade path and bend the metal piece to realign the switch so that the plastic carriage makes contact when reaching the left side. Or replace the whole cutter blade assembly.
Any replacement parts can be ordered from imagingspectrum.com.
Jan 30, 2008 | Sony UP DR100 Thermal Photo Printer
Cricut Expression Cutting Machine Logo
43 people viewed this question
Top Cricut Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Cricut Craft and Hobby Expert? Answer questions, earn points and help others
