Question about Megafeis feis M700 8gb 7" Android 4.2 Tablet Pc
Megafeis m700 Screen locked and doesn't respond. How do you reset tablet?
Where is the reset button on a zeki windows tablet located at
Hi Brenda, The link below is a youtube video showing you how to fix your tablet, Also there's video's down the right side you can check out as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
Apr 24, 2016 | Tablets & eReaders
I dropped my tablet and now everything is backwards words,screen,everything help
Hello! you might need to calibrate your tablet`s sensor, if that doesn`t work please turn off the auto rotation on your tablet, and then reboot your tablet. if that doesn`t work, please do a factory reset on your tablet by pressing power button + volume down, your tablet will go into recovery mode and look for factory reset.
Jul 29, 2015 | Tablets & eReaders
MID model M729B can not get the tablet to respond to unlocking the screen
Here's a link to the manual:
http://www.mymidpad.com/M729B_User%20Manual.pdf
You need to do a hard reset which will wipe all data and restore the tablet to factory settings.
Jan 18, 2015 | Tablets & eReaders
Tablet touch screen won't respond
You may have a damaged wire connecting the screen to the phones mother board
Sep 05, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
How do i hard reset megafeis tablet forgot password
Even if this is not the correct android device, all android devices use this method.
Aug 11, 2014 | Megafeis feis M700 8gb 7" Android 4.2...
How to factory reset a touchtab 7
Alcatel One Touch Tab 7 HD Hard Reset Try this link to know more about how to make a hard reset to touchpads. Electro help
Jun 09, 2014 | Tablets & eReaders
How to reprogram my tablet?
You might be able to return it to the seller as defective
May 26, 2014 | Megafeis feis M700 8gb 7" Android 4.2...
Part of screen doesn't work
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 21, 2013 | Coby Kyros MID7022
Acer tab A200
You may have to perform a reset if your tablet fails to respond when buttons are pressed or the screen is tapped. To reset your tablet use a small thin object (such as a paperclip) to press the recessed reset button.
Or do Clean Boot to restore the Acer Iconia Tab A501 factory default settings.
  • Open Settings from the application menu, then tap Privacy > Factory data reset.
  • Click Reset tablet and then Erase everything to format your tablet.
Jun 29, 2012 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Megafeis feis M700 8gb 7" Android 4.2 Tablet Pc Logo
63 people viewed this question
Top Megafeis Tablets & eReaders Experts
Are you a Megafeis Tablet and eReader Expert? Answer questions, earn points and help others
