Question about Swiss Stauer Deep Dive Watch
Adjusting clasps - Swiss Stauer Deep Dive Watch
Clasp on ebel classic ladies watch is worn. Can it be repaired?
Yes it can be. Take it to a reputable watchmaker and they should be able to adjust your clasp. Usually what happens as a watch is worn for a few years the little brackets that lock the clasps down start to push outwards. so they are not fitting snug against the lock bar of the clasp. A watchmaker should be able to use a jeweler pliers to adjust them back to normal. costs about 15 dollars.
Jan 25, 2012 | Ebel Classic Watches
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
Other than removing links, can I make smaller adjustments to the band on my Omega seamster limited edition?
mcdevito75 here, You should right at the clasp, simply remove the pin and move the entire band up thru the other adjustment holes you see along side the clasp itself. If there aren"t any additional holes along side of the clasp for the band to move up closer to the clasp lock, then no other adjustments can be made.
Aug 18, 2010 | Omega Seamaster 2541.80 Wrist Watch
Received Skagen watch Order No: W256417 today. Mesh Band is too long for me. I do not understand step 2 of instructions Ray Reeves
Ajusting the Clasp - Skagen signature mesh bands are easily adjustable in just three simple steps:
LIFT - SHIFT - PRESS Lift the slotted clasp, Shift the adjustable buckle to the desired position (make sure the clasp is set in one of the indentations on teh back of the band), Press the slotted clasp closed.
Aug 18, 2010 | Skagen Watches
Mens Versace leather strap. How do I adjust the band ? The watch has a cream face, square in shape, chronograph with a brown elather strap. Clip requires adjusting and cant work out how to adjust..
Well i am going to roll the dice and assume you have one of the ez clasps but if I am wrong you can send the model number and we will figure it out.
To adjust the ez clasp pull up on the front of the clasp loop while pushing down on the band. Rather than the traditional buckle and prong set up, the prong here is underneath the clasp loop.
Hope this helps. Thanks!
Sep 20, 2009 | Versace Watches
I need to adjust a Casio AMW320rd-1A9 STAINLESS WATCH BAND. ADVISE PLEASE
This band is put together with cotter pins. To remove the cotter pins look at the edge of the band. The end of the pin that comes out is split and looks like a screw. The end that is solid is the end you want to push from. Use a small punch to push the pin out. The split end is the bigger end of the cotter pin so it needs to come out and go back in the same way it came out. Make sure you remove an even number of links on each side so the watch sits on the wrist the right way. You also have a micro adjustment on the clasp. To adjust the clasp simply use a punch to press the spring bar in the clasp in until it moves. This is a spring bar so be careful it doesnt jump out if the clasp comes apart.
Sep 19, 2009 | Watches
Watch band missing link
Hi lovingdesert ,the only thing you do is go to a service center for watch,if they have clasp like of your Anne Klein,maybe they have an extra. sometimes customer leave thier adjusted clasp. or go to Anne Klein site,and order an extra clasp.
Jun 17, 2008 | Watches
Broken clasp on watch band
The only thing you do is go to service center,maybe they have an extra clasp.Somtimes customer adjusted the size of thier bracelet and when ok they leave their udjusted clasp.That's why some service center had an extra clasp.
Adjusting clasp on a Timex watch
Check that clasp from both sides and you should see spring lug ends. Use small pin to get them out(by pushing in). When pin is out you can adjust bracelet.
Good luck
Arthur
Dec 25, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
Swiss Stauer Deep Dive Watch Logo
13 people viewed this question
Top Swiss Watches Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Swiss Watch Expert? Answer questions, earn points and help others
