Question about Sharp XR-10X Multimedia Projector
Can't change bulb
None
I have a 2001 f150 truck and the left blinker light blinks fast .
A fast blinking light is indicative of a bulb out. If all the bulbs are working check them out especially the contacts in the bulb holders. If all is fine change the flasher relay. If none of this works, it may well be the wiring, and that can be a nightmare to trace.
Jan 26, 2016 | Cars & Trucks
Right brake light does not work we have changed the light bulb and the socket but it still does not work?
Have you checked the fuses?
Have you checked that that new bulb is working? Put the new bulb in the left side, if it works, the bulb is OK.
If none of the above and you have a new socket, then there is a break in the wiring. Good luck with trying to find that, so go to an auto-electrician.
Aug 17, 2015 | Cars & Trucks
99 honda accord cluster
you more then likely fried the board since led bulbs need a converter to make them work. or when you disconnected the board you broke a contact point for the wiring harness connector
May 20, 2013 | Cars & Trucks
How do I change a tail light bulb on a 2008 cadillac CTS
I've got a 2008 cts. And I just checked the lights...None of the rear lights can be changed. NONE! I do not know where these people get their info from. The only light that can be changed are the HID, fog front turn signals and the DRL's!
May 17, 2012 | Cadillac CTS Cars & Trucks
Right side brake light was not working, so i took it out to change the light bulb if the bulb was bad but the bulb still works. I placed it back in and now none of the rear brake lights work and the...
Check your brake light fuse, also make sure you installed the bulb in the right way, if not in the right way will blow a fuse and will also not let you shift gear's due to blown fuse.
Jun 11, 2010 | 2004 Toyota Sienna
None of the brake lights are working on my 2006 mitsubishi galant. I changed both bulbs . I checked brake switch with an ohm meter. I checked all the fuses. Do the brake lights operate through one of the...
Check the wiring going to the chassis holding the brake light bulbs. In the trunk when setting groceries and other items inside someone may have knocked a wire loose.
When you say none of the brake lights did you mean turn signals and parking lights as well on thefront and back?
Apr 16, 2010 | 2006 Mitsubishi Galant
I tried changing the license plate bulb on my 2001 ford focus and I cannot pop the cover back in. I also broke my license plate cover in the process. Now none of the lights in the rear of my car are...
Sounds like something is connecting to the car body, I would inspect the bulb you changed make sure the metal clips or wires are not touching anything.
Jan 14, 2010 | 2001 Ford Focus
One bulb flashed and didnt work after
if you had the unit plugged in when you changed the bulb, then you may have overloaded the circuit board and caused the tracers to burn off the board.
it happens alot when the bulbs are changed.
if you are able to do soldering, then you might be able to put a jumper wire on the board, if not you might have to replace the control board.
Jan 09, 2010 | Kitchen Ranges
Change bulb on 3rd brake light on 2005 honda accord
Check for screws from the inside of the trunk,  If none then unit should slide towards front of vehicle, many melt into place due to high bulb temp in small plastic housing
Dec 09, 2008 | 2005 Honda Accord
Sharp XR-10X Multimedia Projector Logo
16 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
