Question about Coffee Makers & Espresso Machines
Computer not coming on
  • 94 Answers
If the computer doesn't come on but the LEDs are lit on the computer , possibly a bad power supply it is is a 450 wattage and or the fan went out on the power supply. time to replace it mine is 800 watt and is 8 years old , , about $ 35 on the internet or local best-buy ..
Posted on Mar 19, 2014
My computer will not come on and turns the light off on the charger when connected
Most of the time the battery has a short cell inside.
You can try to disconnect the battery and then start the computer.
If the computer will come on the battery is broken and you have to replace the battery with a new one. If the computer still doesn't come on you must go to a repairshop.
Jun 17, 2014 | Computers & Internet
My gentouht charger light comes on but it dont come on at all
the battery must be dead, I plugged the charger into the wall and attached it to my computer. Well, the light was green on the charger, but when I plugged it into the laptop, the light went out on the charger and the computer still wouldn't come on. At first I thought it was the charger, but after testing out different sockets and getting the same results, I believe it's the computer. This computer is brand new and I was just on it the night before and everything was fine. Any help is appreciated.
Aug 08, 2012 | Augen The Book 7-inch e-book Reader...
Aug 08, 2012 | Augen 7" The Book eReader EBGA701 -...
Computer will not come on
You don't state what stage the failure occurs at. The most common hardware failure is a bad power supply. Assuming you have a desktop computer, the power supply is a little box that your 120 volt power cord plugs into on the back of your computer. You have to take the case off to access it and replace it if it's bad.
If your computer tries to come on and goes through the BIOS check, it may notify you of some other kind of hardware failure by a series of beeps. You could have bad memory modules, a failed hard drive, or something like that. On older computers, a bad battery on the motherboard can keep you computer from coming on until you go into the BIOS and update the date & time.
A corrupted operating system can also keep your computer from coming on. This can happen after an update has been performed or if you somehow picked up a virus.
May 20, 2012 | Dell Inspiron 530 Desktop Computer
Fan comes on frequently on hp computer. dust etc
If this is a desktop computer, did you clean out all the dust inside the computer? You can buy cans of compressed air at places like Staples. Make sure you blow the dust out of the power supply and cpu heat sink.
Mar 23, 2010 | Computers & Internet
My computer come on
mcdevito75 here, Check all your electrical connections, Check the wall socket or 1 you know is good see if the computer will come on. Also there may be a fuse on the back of your computer protecting it against surge this fuse usaualy has a special cover on it, most times it"ll look like a large screw head that you can simply un-screw to check, check this fuse with your computer off and out of the wall.
Jan 24, 2010 | AOpen AX45-V (91.88I10.004) Motherboard
Will not come on. I have checked both the cables (power and computer)and they are ok. When pressing the power button the green light in it flickers slightly but monitor will not come on.
remove the cable from the back of the computer with the monitor and computer turned on. If it gives you a no signal error either the cable or your graphics card inside the computer needs to be replaced.
Sep 07, 2009 | ViewSonic VX710 17" Flat Panel LCD Monitor
My monitor light comes on but there is no signal.
Isolate the problem. Connect the problem monitor into different computer. If the problem monitor worked on another computer, try connecting a CRT monitor to the problem computer. Once the display comes back, change the screen resolution.
Jul 29, 2009 | Gateway FPD1775W Monitor
When I push button to start computer the windows doesn't come up.
When you turn on your computer, can you hear the bios "bleep". If you don't then press the reset button and your computer should boot up normally. If this doesn't work, then your replacement switch may be faulty. If you're replacement switch is not exactly the same then you may have the wires in the wrong lugs.
Apr 26, 2017 | ASUS AMD 751 Chipset K7M (K7M/500/WA)...
Coffee Makers & Espresso Machines Logo
16 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
