Question about Toshiba Satellite Pro L300 Notebook
When I turn on the L300 laptop it says at the bottom press F2 or F12 . When i do it goes to boot menu. If I hit any of these it then goes to No bootable device - insert boot disk. i did not obtain any discs with the laptop. DO i need to take it to repairers or can you help fis it as it is needed for disabled son at school tomorrow?
  • 152 Answers
You have to reinstall the operating system ....I suspect that ur Hard drive is needs to be replaced ...
Posted on Jun 14, 2009
Got an Acer 4050 from ebay and it goes straight to enter boot password
can you click on f12 before it goes to boot password?
The F12 Boot Menu allows you to choose which device that you would like to boot the computer's Operating System from by pressing the F12 key during the computer's Power On Self Test, or POST process. Some notebook and netbook models have the F12 Boot Menu disabled by default.
If this sounds like your problem then try this:
If this sounds like
To enable the F12 Boot Menu:
  1. Restart the computer.
  2. Press the F2 key to enter computer's BIOS Setup during Power-On Self-Test, or POST, process while the Acer logo is being displayed.
  3. Press the Right Arrow key to select Main
  4. Select F12 Boot Menu
  5. Press the Enter key
  6. Select Enabled
  7. Press the Enter key
  8. Press the F10 key and then press the Enter key to save the changes and restart the computer.
Note: Not all Acer notebooks or netbooks have the F12 Boot Menu feature. Computers that do not have the F12 Boot Menu feature will not be able to enable the feature within the BIOS. I hope this works for you if not, then the problem is obviously not the boot menu. Go to Acer support for more help
Aug 30, 2014 | Computers & Internet
Boot menu cant working
Press DEL to get to your bios options then disable fast boot. This will allow you to hit the appropriate key to enter the boot menu.
Mar 30, 2014 | Lenovo Computers & Internet
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
My toshiba sattelite l300 crashed on my children when i tried to start again it would not witch on i tried in safe mode and worked i then have tried again and screen just takes me to restore computer. i...
Please do follow steps:
Switch your notebook ON
Press immediately F12 to enter boot selection device menu
Choose CD/DVD drive and press ENTER
When menu is shown and your language is marked confirm with OK
On each step just confirm with OK and recovery installation will starts properly.
ALL data on HDD will be deleted.
Jun 30, 2010 | Toshiba Satellite Pro L300 Notebook
My acer aspire 5315 always show boot prepare os. When i want to install windows it cannot show cd boot (booting from cd/dvd) so i can't install windows. what is the solution sir? thank.
Restart you computer then hit F2 for Boot Bios Setting then GO TO Advance. Change the SATA Mode . ACHE. ot IDE. or Comfatibility.. then enable the F12 boot. make in enable. the hit F10 for save and exit...
Insert you cd os Installer then hit F12 for **** menu. select the CDROOM for boot....
Dec 30, 2009 | Acer Aspire 5315 Notebook
L300 wont work
Were there any changes made before this happened?....software..hardware...any thing downloaded?
Jun 11, 2009 | Toshiba Satellite Pro L300 Notebook
Cmos / Bios password
IF IT COMES TO A SCREEN THAT SAYS "TOSHIBA" AND AT THR BOTOM LEFT SAYS ''F2-UTIITY , F12- BOOT MENU'' CLICK F2 IMIDITLY AND USING THE RIGHT CONTROL BUTTON SCROLL TO ''SECURTY'' AND CHANCE THE PASS WORS
Apr 03, 2009 | Toshiba Satellite Pro L300 Notebook
Can't boot up my HP XE4100 laptop
press hard disk and boot the windows
Apr 01, 2009 | Computers & Internet
Bios batt
if you leave it long enough does it boot ?
press F2 and go through the settings and check for something like "display boot menu" or similiar.
remember to save your settings upon exiting
Sep 20, 2008 | Toshiba Satellite M100 Notebook
Can not Boot from OnBoard SATA Hard drive.....it keeping looping...
Turn on (or restart) your computer.
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F12>.
The Boot Device Menu appears, listing all available boot devices. Each device has a number next to it.
At the bottom of the menu, enter the number of the device that is to be used for the current boot only.
If this works and you want to change the setting permanently do the following:
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F2>.
Use the arrow keys to highlight the Boot Sequence menu option and press <Enter> to access the menu.
NOTE: Write down your current boot sequence in case you want to restore it.
Press the up- and down-arrow keys to move through the list of devices.
Press the spacebar to enable or disable a device (enabled devices have a checkmark).
Press plus (+) or minus (–) to move a selected device up or down the list.
Feb 17, 2008 | Dell Dimension 4700 PC Desktop
Toshiba Satellite Pro L300 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
