Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
What file do i use on a .325 pitch chain - Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
What other chain can i use on a stihl 025
You need to know three things about your saw as to what chain will interchange....1. Pitch of the chain. 2. Guage of the guide bar. 3. Number of chain links.
Your little 025 Stihl wil probably have an .050 guage and a .325 pitch. The standard guages for small saws are .043, .050 with .058 and .063 being reserved typically for the larger displacement saws.
The pitch is the length of three links, divided by two and the number of links is kinda self-explanatory. (The 025 USUALLY is set up for the .325 pitch.)
Any chain that matches the three measurements for your respective saw should interchange. Hope this helped instead of adding to the confustion......
Sep 18, 2015 | Stihl Garden
What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
50:1 ratio to a gallon of gas. Non ethanol if you can find and a octane rating over 87
Dec 30, 2014 | Homelite Garden
Filing angle for Husqvarna chainsaw 450 --20 ' bar chain 72 links?
On .325 pitch chain the top plate angle should be 25 degrees, there is normaly a match mark on top of each cutter, the depth gauge should be set at 25 thousands of an inch.
Apr 02, 2013 | Husqvarna 450 Chain Saw 18 Inch Bar...
What is the file size (to sharpen chain) for a Poulan Pro 295 46cc?
I am pretty sure this machine ran a .325 pitch chain, so the file size is 3/16, if it is running 3/8 low profile chain ( 91 ) it will be a 5/32 file, the pitch should be marked on the bar .
Sep 16, 2011 | Poulan Pro Chain Saw 46cc 20"
What bar and chain for a 359 chainsaw husky
Depends on what lenght you want, as standard it runs a .325 pitch, 058 gauge chain, bar lenghts are available in 13,15,18,20", you can convert them to a 3/8 pitch chain by changing the the rim, or changing the complete sprocket and oil pump drive gear.
Sep 10, 2011 | Husqvarna Garden
I have husquavarna chain saw s/n 95212H01984 with sticker that says 41 Air Injection. Need to buy chain and/or chain bar. Need to know the model number for this serial number. Can you provide
The saw is a 41, as standard it ran a 15" bar and chain, in the UK it ran a .325 pitch, however in the US, it ran a 3/8 pitch chain, as you should change the sprocket if fitting a new chain, i would put it on .325 if it is not already, the sprocket is part no. 530069342, the 15" chain is 501840664, and the guide bar is 508926164 these are .325 pitch 050 gauge and 64 drive links, this combination will cut much faster than the 3/8 low profile combination.
May 13, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need to know the degree to set my electric chain saw sharpener for husqvarna chain. This is a 20 inch chain.
A 20" bar unfortunately does not narrow it down. Fortunately both the .325 pitch chain and the 3/8 pitch chain sharpen at 25 degrees and you should have one of these chains. Hope this helps.
Mar 01, 2011 | Husqvarna Chain Saw 20" Bar
After new clutch sprocket &good bar &chain chain r bar moves prematuely and chain comes off bar nuts r tight
have you made sure that chain pitch and gauge are the same as the sprocket pitch pitches can be 3/8 lo pro 0.50 gauge
.325 x 0.50 gauge , .325 x 0.58 gauge
3/8 std x 0.50 or 3/8 x 0.58 gauge or 3/8 x 0.63 gauge
you could even have the correct drum but wrong rim sprocket on it
worst case is you could have mismatch bar and chain
make sure that bar adjjuster assy is working correctly
recheck chain / sprocket pitches and bar pitch and groove
gauge
be sure that you fitted chain to rim on sprocket correctly when you fitted bar and chain?
is the clutch cover pulling down tight ?
have a look and let me know if and what you find
cheers paul
Aug 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
What is the pitch
the pitch should be on the bar, if not you could measure the distance between three rivets and half it. It'll either be .325" / 8.25mm or 3/8" / .375" . 9.25mm .
Apr 19, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
37 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
