Question about Refrigerators
Replace red light on door
Mod 596.78533802 series ko4065824
Razor Bistro scooter won't take charge - light stays red
i had the same problem with mine and it ended up being that one of the batteries was bad, there are two 12v batteries wired in series under the seat, usually you can tell which one is bad by looking at them, one of the batteries will be swelled up
May 09, 2012 | Razor Pocket Mod-bistro Retro Scooter
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
I need help replacing my switch lid on my Kenmore 70 Series mod. # 110-22722100 Washer. Can anyone help me with this??
if you have a gray switch than you nead to bypass the switch.if you replace the switch it will brake again.you do not nead a door switch.
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
TV not working after replacing lamp
yes, the door has to engage a switch and if it doesn't the tv will not come on it usually has a 3 blink error if this is the problem. Is your red light flashing in a 3 blink series?
Sep 16, 2009 | Sony KDS-R50XBR1 50" HDTV
XBOX has flashing red light, need to know how to fix the problem
You should be getting an error code on the screen. Depending on that code, you will need to fix it in different ways. If you're getting a hard drive error, you will need to mod the system with a mod chip and replace the hard drive. if it's an other error, you will need to replace the system. The easiest thing it to buy a mod chip. There are many solderless chips out there for under $40. If the lights are flashing yellow and red, then that means the av cable isn't connected.
Aug 25, 2009 | Microsoft Xbox Console
Top two red lights flashing on my 360
To find out whats wrong with your system press and hold the sink button then press the eject button. You need to do press the eject button 4 times each time you do this you will get a series of flashing lights. All four lights meen 0. 1 light is 1. 2 lights is a 2 and so on. Once you get the four numbers you can check online to find out what's wrong with your system. If you are comfortable working with electronics I can help you fix it. Contact me at console.mods@yahoo.com so I can walk you through it.
Jul 19, 2009 | Microsoft Xbox 360 Console
Mod.139.53671SRT no clous
If the main light is flashing 10 times when the door reverses it is the door sensors. Most likely misaligned. Each of them should have a small light that is lit and not flickering. Usually a little tweaking will fix the problem.
Jul 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
