Question about Vehicle Parts & Accessories
How to change PCV valve 1997 Nissan Quest
How to you get to it
  • 467 Answers
Posted on Jan 08, 2017
1997 Nissan Quest what kind of transmission fluid and how much when replacing
1997 Nissan/Datsun Truck Quest Mini Van 3.0L FI SOHC 6cyl
The Transmission Fluid Type/Capacity
Nissan Matic D or equivalent.Total fill: 9.9 quarts.Service change: Data not available.Here's a link for your fluid. Castrol DEXRON VI Transmax automatic transmission fluid 06822 Read Reviews...
Apr 05, 2017 | 1997 Nissan Quest
Where is the pcv valve located
I found this picture. The pcv appears to be in the valve cover. I didn't check to see if ohc engine?
Apr 18, 2016 | 1999 Nissan Quest
How to replace pcv valve on 2001 nissan quest
It will be located in one of the valve covers but nissan has used a fixed orifice crankcase vent sysrem which would just be a vacuum line fittings with a small opening inside the line from that valve or orifice would connect to manifold vacuum (intake maifold after the throttle plates)
Jul 03, 2015 | 2001 Nissan Quest
Where is the pvc valve located
PCV is located at the PCV next to the jigger port
May 13, 2012 | 1997 Nissan Quest
Where is the pcv valve located. and is it easy to change?
pcv valve is on backside of engine. it screws in to engine behind idle air control. you will need a socket to remove it. have a good day !
May 13, 2011 | 1995 Nissan Quest
Where is the Pvc valve on a 1997 nissan xe pickup?
1997 Nissan pickup its just above the oil filter, lower right of engine, access through right front wheelwell after removing wheel, it's a screw to be removed. -------------------- The pcv valve on the 2.4 l engine is located behind the alternator and the engine oil filter. The best way to change it is to go thru the wheel well. Take off the passenger front wheel, lift or remove the rubber splash curtain, remove the oil filter, disconnect the rubber vacuum hose, then use a 19 mm wrench to remove the pcv valve. ----------
Thanks. keep updated for any more can rate this solution and show your appreciation.
Sep 22, 2010 | 1997 Nissan Pickup
Why do I get white smoke only when I start the engine on my 2007 nissan quest? Could it be the PCV valve?
It could be the pcv vavle or or you could have some bad piston rings that are leaking by
Jul 29, 2010 | 2007 Nissan Quest 3.5 Minivan
I have a 1997 nissan quest XE. I can drive it to
clean throttle body and the idle air control valve which is bolted onto the trottle body and it should fix it
Dec 13, 2009 | 1997 Nissan Quest
1997 nissan pick up 4x4
First turn the steering wheel all the way to the right. Then use some pliers to carefully remove the plastic retaining clips that hold the splash guard in place in the right front wheel-well. You should now be able to see the oil filter (incidentally this is how you access the oil filter). Remove the oil filter. You should now be able to see the PCV valve and its hose which connects to the intake manifold. Use pliers and loosen/slide the retaining clip up the hose a couple of inches (this will alow the PCV valve to rotate as you unscrew it). Use a "stubby" open wrench to unscrew the PCV valve. With the PCV valve removed from the crankcase it is now easier to remove it from the hose. Reverse the process with a new PVC valve and you are finished. Appoximate time 30- 45 minutes.
Oct 07, 2008 | 1997 Nissan Pickup
Vehicle Parts & Accessories Logo
53 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
