Question about Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
Ice maker stuck - Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator
Sub zero 650 slow ice maker
Hi Maureen,
Your sub-zero 650 should produce about 8 cubes every 2 hours. It sounds like the heater beneath the ice maker may be wearing out. Ice makers use a heating mechanism to warm the cubes in the mold and force them to easily eject. If the heater is failing in the back slot, it could cause the ice cube to get stuck. If this is the case, you usually need to replace the part or the entire ice maker.
It is also possible the mechanism isn't properly aligned. You could try adjusting it.
You can find two manual on FixYa here: http://www.fixya.com/support/p24667-sub_zero_650_o_bottom_freezer
Otherwise, I suggest contacting their customer service or a technician: http://www.subzero-wolf.com/contact-and-support/index.aspx
Best of Luck!
Dec 09, 2013 | Refrigerators
Frigidaire refrigerator glhs38egsb0 ice maker freezing up
Hi - Is the wire signal arm in a stuck position or has any ice cubes stuck? If so, try turning it off and remove any ice cubes stuck to the wire signal arm or body of the ice maker and wait approximately 8 hrs. Should these suggestions prove to be ineffective and ice maker continues to freezer up, I recommend contacting a professional to properly diagnose and repair the unit.
Sep 29, 2012 | Refrigerators
SAMSUNG MODEL RS2533SW/CUR ICEMAKER MAKING ICE BUT NOT DUMPING
This sometimes happens with my KitchenAid ice maker.
Usually there is a piece of ice stuck on the side where the sensor is that causes the ice to drop. I usually carefully chip away at any ice that is stuck. Once the stuck ice is removed, the ice maker works fine.
Sep 18, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
The ice maker wont drop the ice
Try this pour Hot water in ice maker it may be stuck then see,if blades turn there could be something stuck in ice maker.write back (I had a piece of plastic bag get stuck on the rotateing blades that push the ice up to the drop tub underneath) I hope this works for you
Aug 29, 2010 | Whirlpool Refrigerators
My ice maker fails to make ice, and seems to get "stuck" between batches, causing a clicking noise that occurs continuously about every 30 seconds. Any suggestions?
check for a stuck ice cube, something is preventing your ice maker to advance, if there is no ice cube, replace ice maker part #wr30x10093 for standard in freezer ice maker or part #wr30x10097 for ice maker in refrigerator
Aug 26, 2010 | GE Profile Performance 23.5 cu. ft....
Ice maker not making ice. ice in the tray, but will not dump the ice
Its the bar and gears that has frozen.
There is a stainless bar on the front of the ice maker. It move out and back to check for ice in the bucket. This bar is stuck and the ice maker thinks there is no need to harvest ice.
Try to move this bar and I bet it is stuck.
You can get a new Ice maker from Ebay and replace it yourself.
Jul 24, 2010 | LG LFX25960ST Stainless Steel French Door...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker stuck
Switch the ice maker off then back on should reset it . It is possible that the 'ice mould heater' is not working so the ice cubes don't realease from the mould , jamming the motor. Replacement ice maker is usually the solution
Aug 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Cube maker stops making cubes as they are being made ....
Ice makers use a small heating element to release the ice from the mold tray..sounds like that isn't working and everything else is. Check to make sure all electrical connectors coming from the ice maker are properly seated into their mating connectors. If that doesn't solve your problem, you may be better serevd by just replacing the entire icemaker assembly.. Hope that helps...
Jul 25, 2008 | Frigidaire FRS26R4A Side by Side...
Electrolux EW28BS71IS (278 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
29 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
