Question about Sharp R-1460 Microwave Oven
Dm150v thermo fuse
Fuse is open
PVM1870SM3SS will not power up found burnt THERMO SW-TCO SENSE TEMP
This part is a Cabinet fuse and will stop power to the control panel, works through L1. This open or fails when the microwave cabinet get too hot and it is protecting itself.
So yes to your question.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 24, 2013 | GE WB27X1127 WB21X535 THERMO SW-TCO SENSE...
No power. Unit was working fine when it shut down. no power of any kind. Unit is plugged in properly and outlet has power.
has a blown inner fuse or a open thermo (under the oven cavity ceiling or on the magnetron). if it's the main fuse out, you probably have a failed component.
Aug 06, 2011 | Samsung SMH8165B Microwave Oven
Samsung microwave dead---less than two years old
if totally dead; check the main internal fuse and magnetron / oven cavity thermos. it will need to be removed from wall and diassembled to diagnose.
Aug 03, 2011 | Samsung SMH8165STE Microwave Oven
After lightning strike & power outage digital display & oven not working. is there a fuse or reset button? or is the circuit board fried?
Start by investigating, open at the point where power cord goes in there is a fuse if it is o.k there is another smaller trans former powering the display board that normally uses thermo fuse, find out whether the thermo fuse is blown i hope this solves your problem
Aug 02, 2010 | Microwave Ovens
My microwave just stopped...no power...circuit breaker was fine just no power to the microwave
Some units have a fuse inside that may be bad or there are thermo fuses that may have failed in the cabinet. Take it to a servicer or just buy a new one.
Sep 03, 2009 | Panasonic NN-S562 Microwave Oven
Dryer is over heating, all thermo have been replaced along with motor and belt. Turn on and still shuts down and smells like its burning. Dryer is hot to touch.
dryer element is fused to metal housing thereby heating all the time as the element is grounded all the time making a closed circuit
Apr 17, 2009 | Maytag MMV4205 Microwave Oven
Emerson mw
Call any service center that services appliances or most any electronics parts supplier. You will have to know the specs of the thermo fuse to order one.
If the thermo fuse is blown, most likely there was an overheating condition, and there is a failure somewhere. This can be a serious safety issue. When you change the fuse, it may blow again. It would be best to verify the specifications and for proper operation of the unit before using it again. A qualified service center for microwave ovens can do this for you.
Jerry G.
May 03, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave dead
First, there is an outlet. Plug in something else. Inside the key panel, there are fuses and a thermo sensor. Either may be bad. The thermosensor is about the diameter of a dime, black and 3/8 inch thick...attached to the wall of the chamber. All should have continuity.
Dec 20, 2007 | Whirlpool GH7155XHS Microwave Oven
Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Dec 18, 2007 | Goldstar MV-1501 Microwave Oven
My microwave is a 2005
jl, first, are you sure that you have power? Plug something else in to check. Also, unplug the unit, wait a full minute and repower. Sometimes this resets the units. Second, fuses are generally located inside the keypanel area. With the unit unplugged, remove the screws holding the panel on. Inside, you will find at least one fuse. You will also find thermo sensors. They are black, about the diameter of a dime and 3/8 inch thick with two wires coming out of them. Check them for continuity.
Dec 18, 2007 | Frigidaire PLMV169DC Microwave Oven
Microwave Ovens Logo
89 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
