Question about Microsoft Windows XP Home Edition
Start_up_error My system is receiving start up error that is windows cannot find "C:WINDOWSFontsExplorer.exe". Make sure you typed the name correctly. Im using windows XP only...  The above start up error is making my system to slow down also. Please help me mam....
  • 4,889 Answers
Re: start_up_error
Ok..try this.. Click on start->Run->type msconfig-.Click on startup tab and see if you can find any application running from the location u have specified..If ye just un-check apply and restart your system and it should be ok..
Posted on Oct 30, 2007
0 characters
3 Points
I'm trying to install microsoft picture it but a missing pi.exe notice keeps on apearing,how can I fix this?
What others are doing:
Try the free download
Free Guides to Fix PC Errors By PcTweaker pi.exe is part of Microsoft Picture It! 9 and developed by Microsoft Corporation according to the pi.exe pi.exe Vendor and Version Informaiton : Product name : Microsoft Picture It! 9 Company : Microsoft Corporation Version : Md5 : 33be8a09351e58d22e5a3f35cff5ffa6 Why does my computer have the pi.exe wrong information cue? pi.exe is a file name that often appears in some error messages on the computer, if you frequently receive the error notifications which state that the specific program cannot be processed for the pi.exe file being corrupted or missing, you should consider to fix pi.exe error well for avoiding the related operation problems on your computer.When this file gets corrupted, missing or suddenly become invalid in the Windows system, you will immediately receive the pi.exe error message and you will need repair it as soon as possbile !
If you do not fix nengine.dll missing as soon as possible, you may face the problems below:
"System boot-up failure" "System file corrupt" "Slow system performance" "Blue Screen of Death errors" "White Screen of Death errors" Why the need to Fix pi.exe Errors ? When the system has the pi.exe wrong information, it shows that the error has been affecting the Windows system's running stability. If this time not clearing up the pi.exe error quickly, the Windows registry can be easily damaged, and then the unsteady Windows registry will affect the normal use of other softwares or directly make them not work,and the whole Windows system can not be used normally.So, when the Windows system has the error message, we should hurry up to repair it well.How to fix the pi.exe error ? To fix pi.exe error is not that easy before,but now it is so easy ! Please download the Pctweaker software recommended by us, according to the following procedures. You can soon clear up the pi.exe error through a few simple procedures, and in the course the software will automatically repair your computer's Windows registry damage caused in normal operation.
Jul 23, 2014 | Operating Systems
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\ xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\ xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\ xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 ( ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 ( ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
Shotter..exe problem
Please follow the steps:
Go to Start-->run, type..regedit Go to Edit-->find shooter.exe , press F3 until you find this entry named as "shell" c:\Program files\Ecspecialist...\shooter.exe right click-->delete
Aug 31, 2009 | Microsoft Windows XP Professional
Cannot find gphone.exe
gphone.exe is a virus that affect google talk or yahoo messenger, to remove it you can download a copy of Eset antivirus.
You could have the same error after the antivirus removal but now the system is clear and you have to delete gphone.exe from your startup files list: start -> run -> msconfig -> go to startup and uncheck gphone. This should help you.
Jul 18, 2009 | Microsoft Operating Systems
Every time I start my computer running Windows XP, I get the following message: ''Windows cannot find 'C:WINDOWSSystem32WinSit.exe'. Make sure you typed the name correctly, and then try again. To search...
just click start and select run and typr msconfig. u will get a menu and in that click startup ..u will get a list of files loading in startup. untick the one appearing in ur error. and restart
Apr 10, 2009 | Operating Systems
Windows Startup Error csrss.exe
Okay, we are going to try two things. If the first don't work go to the second.
1) First perform a search on your computer for the 'csrss.exe' file. If found, copy it and then paste it into your C:\windows\system32 folder.
That should do it.
2) If that don't do it or your search can't find it, then perform the following;
To scan and verify the versions of all the system files that Windows File Protection protects, use the System File Checker (Sfc.exe) tool together with the /scannow parameter. If the SFC.exe tool detects that such a file was overwritten, the SFC.exe tool retrieves the correct version of the file from the Dllcache folder or from the Windows installation source files, and then replaces the incorrect file.
To run SFC, please follow these steps:
1. Click on Start > Run command prompt
2. Type SFC /scannow, and then press ENTER
Note: You may be asked for inset OS CD.
3. After finishing SFC, you may run CHKDSK C: /R in the Run command prompt as well.
Feb 14, 2009 | Microsoft Windows XP Professional
" windows cannot find 'regsvr.exe'.
type in run "msconfig:
then go to starup then disable all.thenrestart the system.thats all dear .
Jan 05, 2009 | Microsoft Windows XP Professional
Error in application download due to regsvr.exe is missing
Window is asking about Regsvr.exe file at the start up.
Dec 26, 2008 | Microsoft Windows XP Professional
Whenever I start my system I first get an alert before login of profile as "crmgoldbpe.exe - Common Language Runtime Debugging Services Application has generated an exception that could not be handled....
click start -> run. Type msconfig hit enter. Goto the startup tab and look for anything containing crmgoldbpe.exe and uncheck the box next to it. Restart your computer. The error should be gone. This is part of a spyware program so you should also run an anti-spyware program such as spybot search and destroy from
Dec 19, 2008 | Microsoft Windows XP Professional
Cannot find regsvr.exe
Download and run this:'s a virus you have. It will get worse if you don't clean it or restore your computer.
Oct 24, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Home Edition Logo
29 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
