Question about Polaris Pb4 - 60 Booster Pump
Installed a new pump but won't work
We have power but will not run pump
    Top Expert:
  • Polaris Master
  • 5,061 Answers
Check voltage to unit check side of motor for wiring schematic if 120 volt change wires
Posted on Apr 23, 2016
New fuel pump won't prime. No fuel from gas tank to engie. Lines are clear.
The pump works without priming anything. If the tank is vented, and you have fuel in the tank, and the pump is installed correctly, it should pump fuel out.
Are you sure the pump is getting power and ground ?
Jun 24, 2013 | Mazda Protege Cars & Trucks
New fuel pump won't run
I have had bad pumps rite out of the box but dont assume its a bad pump check for power at the pump with a test lite remember the pump only has power for 10 or so seconds after key is on if vehicle dont start pump will lose power until key is turned off then you have to turn key back on best if done with 2 people
Jun 07, 2012 | 1994 Ford Econoline
3/4 hp pool pump and gas heater won't run. Both are on a 30 amp breaker. power goes to the pump and heater but nothing runs
USE A VOLT METER , START AT THE BREAKER AND WORK YOUR WAY TO EACH DEVICE. THIS WILL HELP YOU TRACK DOW THE POWER ISSUE .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
May 18, 2012 | Pool & Spa
1999 gmc 4.3l won't start
P0147 Heater circuit malfunction bank 1 sensor 3
P0452 Evap spressure system low.
P1345 This is the main problem your solution is a whole new distributor,dont bother trying to retartd or advance the timing it wont start and if you do get it to start it will just sputter, you going to have to remove the camshaft and install a new one.
Apr 22, 2012 | 1999 GMC Jimmy
It will crank but won't stay running
installed new fuel pump and filter in 97 cavalier 2.2 the car will run for a couple seconds and shut off if you spary it with starting fluid it will stay running
Apr 13, 2012 | 2003 Dodge Durango
Fuel pump won't run unless engine is cranking, but won't start
Are you sure it's running when cranking? It should have come on when key turned on.
This is for camrys up to year '91. It may apply in your '95, also. Check the 7.5 amp ignition fuse and the 15 amp EFI fuse and the EFI main relay, all located in the fuse box next to your battery. There is also the circuit opening relay tied in to fuel pump operation. It is usually found under center of dash. It is usually not the problem, but it is part of the checks for fuel pump operation.
If your car has a " check connector" or "service connector" (also called a fuel pump check connector) under hood on driver's side near the firewall (a little 1 inch cube with a cap on it), then bridge terminals +B and Fp with a jumper wire. Turn key to on (don't start car). The pump should come on. Listen for fuel return noise from the fuel pressure regulator, and verify pressure in hose from the fuel filter. If nothing, check those fuses above. Here is how power runs to pump: Battery to 40 amp main fusible link-to 15 amp EFI fuse-to EFI main relay-to circuit opening relay-to fuel pump-to ground. Ignition switch and the computer (ECU) work the relays to pass power to pump. Hope this helps some, Randy. Good luck.
Nov 10, 2011 | 1995 Toyota Camry
Help me with my 1993 chevy cavalier 2.2L engine. My car won't turn on when ignition switch is in the on position. When I turn it to the on position, my radio cuts on, and my air conditioner turns on,...
what do you mean by "dash lights"? how do you KNOW the pump isnt working? how do you KNOW its good? at the ignition switch the ORANGE and PINK should have power in the RUN position the BROWN and TAN/WHITE should also be HOT in the run position. There should be a red wire near the fuel pump relay, make sure its HOT when cranking. IF its HOT and the fuel pump doenst run, the pump is bad. You can also put 12V on that red wire and power the pump.
Aug 26, 2011 | 1993 Chevrolet Cavalier
2001 Buick Century. Fuel gauge didn't work. I bought a new fuel pump with fuel level sensor on it, installed, car will not start. I replaced the fuel pump relay, put the OLD fuel pump back in with...
I had a Grand Prix one time (basically the same car) that had a problem with the fuel pump harness. This harness plugs into the top of the fuel pump as you know, and into the floorboard underneath the car. Check the floorboard end for corrosion or broken wires.
Aug 19, 2011 | 2001 Buick Century
96 olds ciera quit no gas at schrader valve so installed new fuel pump an filter I have no power at the pump where do I go now
You should have a relay or a fuse, I forgot the number but it is located under the hood of the vehicle, the fuse may be located itself under the drivers dashboard
Jun 11, 2011 | Oldsmobile Cutlass Ciera Cars & Trucks
I have a new pump and there was no power going into it. so i ccut the wires and want to run it to another power source. can i run it to the fuse box and it work the same? also since its fuel injected i...
did you check the fuse for the fuel pump you don`t say.there is also a fuel pump relay in the system.if you bypass the system then the ecm won`t have control for the pump,which controls the 2 second prime at the beginning when key turned on and it won`t shut off the pump in case of an accident when the engine stops.you can bypass it but its not recommended because this.if you do bypass make sure you have a 25amp fuse wired into the power wire and a on/off switch that you must remember to turn on and off every time you drive the car.
Mar 31, 2011 | Chevrolet Caprice Cars & Trucks
Polaris Pb4 - 60 Booster Pump Logo
56 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
