Question about Philips 40PFL3705D 40 in LCD TV
Wont turn on
Will not turn on either manually or with remote
Kids stepped on remote.tv wont stay on-it turns off immediately. tried resetting.still turns off. wont stay on.
Pull the batteries out of the remote, and turn the TV on manually if you can. If it still goes off, your problem is not in the remote.
May 22, 2015 | RCA Audio Players & Recorders
I cant manually turn on my tv to progarm universal remote
You have this backwards. The TV does not program the remote, the codes for the TV are generated by the remote. If you cannot turn on your TV by using the power switch on the front, there may be a power supply problem.
Nov 10, 2013 | Televison & Video
Remote wont turn tv on
If your remote serves multiple units, make sure it's in the right mode for your TV. (not dvr, dvd player, tuner, other source...). If the TV will not turn on manually (with the power switch on the TV), then make sure it's plugged in and there is power at the plug (try a different power source). If your remote has been out of battery power, sometimes it needs to be reset / reloaded with the correct code for your TV. Check your remote and / or your TV manual for the procedure.
Apr 09, 2012 | Car Audio & Video
Just opened up a panasonic TC-L32C3 from its box, pluged it in and the remote (with brand new batteries) wont turn it on. I am able to turn it on manually and went through the initial on-screen set up...
Yes,the tv manual controls board infered signal light from the LED diode,to the tv have problems.Take the tv back where u bought it and exchangce it for another new tv.
May 21, 2011 | Televison & Video
My 3.2 IR 166173 BELL remote wont work on my bell reciver
Ensure that the TV is turned on. Turn the Bell receiver on manually (at the receiver). Remove the batteries from the remote. Press the "Power" button on the remote until no buttons on the remote light up (a half-dozen times). The satellite service (your Bell service) will likely have turned itself off in the process. Replace the batteries in the remote. The remote should now work as "normal".
Nov 26, 2010 | Televison & Video
I have a 32 in insignia and a universal remote was used to try and turn channel..it turned the channel once and now its frozen on that channel even the tv remote wont work and the manual buttons on the tv...
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Mar 24, 2010 | Insignia NS-LTDVD19-09 LCD TV
Parental control is LOCK
mitsubishi 45605 . I bought a universal remote and it wont respond anymore. I tryied reprogram and it wont take the old code or any code. I bought a new remote and it wont respond
Apr 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
2000 Chevy Blazer Won't Start
You can check the manual that came with the Remote starter.
If you do not have one try look it up on line.
You can try call the people that install that kind of remote starter.
Some started do a lot more than start your car and the only way to know is to look at the manual.
You are trying to find out if it is has a ignition kill command.
Mar 16, 2009 | 2000 Chevrolet Blazer
Lost the remote to the tv now it wont turn on manually
the remote has nothing to do with the tv not turning on or off you should be able to push the power button on front of the tv and turn it on that way.if its not staying on then theres something more wrong than just a lost remote
Jan 21, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Philips 40PFL3705D 40 in LCD TV Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
