Question about CEN-TECH Digital Scale
Will not calibrate saying something on platfrom when there is not
My Goodmans 5012z camera says calibration needed.how do I do the calibration?
Are you sure, you are using it in automatic mode? I can't find a manual, but when you were in any menu, you could have changed your camera in something you can't handle. Please look if you can put it in automatic.Perhaps it is with the mail dial, perhaps you have to go into the menu's.
May 27, 2014 | Goodmans G-Shot 2025TFT Digital Camera
I want to change startup flash screen (please Wait)
You can not modififi in intel platfrom.
Let me know if you need more information
Thanks
Feb 13, 2011 | Intel D945GTP Motherboard
Tony hawk shred board will not calibrate even with enough clearance all around keeps saying something did not go through.
I had the same problem. Do not use the batteries that come with the board. Use slightly older batteries and re-calibrate the board, this should work.
Dec 25, 2010 | Activision Tony Hawk: Shred
CANNOT CALIBRATE XBOX 360 SHRED BOARD. kEEPS SAYING "something didn't go through, lets try it again
I had the same problem. Do not use the batteries that come with the board. Use slightly older ones. After switching the batteries re-calibrate the board and that should do the trick.
I do not see the print screeen button on my keyboard. Is it represented by a symbol? I have the Logitech S 530 Mac keyboard Thank-You
If you are using This keyboard for Windows XP / Vista or 7.
Please use key F13 - That is the PRINTSCREEN button for Windows Platfrom.
Please Vote me If it solved your problem
Sep 17, 2010 | Computers & Internet
Compass calibration
im taking an educated guess- ive done it maybe once or twice in a chrysler- try to go into the MENU by hitting the buttons for menu and reset. if u luck out it will say something like calibrate or calibrate compass on the screen. now it will either tell u what to do or if not drive carefully in a small circle slowly clockwise and then counterclockwise several times. as youre doing this it might suddenly pop up "calibration complete" or something similar. i almost forgot- IF U HAVE THE OWNERS MANUAL ,LOOK IN THERE 1ST. if not try what i said.
Aug 09, 2009 | 1991 Pontiac Grand Prix
Will not down load on Mirosoft Vista Platfrom...
w-10 is not recognized in vista. call or email olympus tech for the downloads for your vn-960pc
Aug 22, 2008 | Olympus WS-100 Digital Voice Recorder
Vista compatible software can be downloaded here:
http://downloads.olympus-europa.com/consumer/VoiceRecorder/720/eng_2000_xp.zip
After installing the software you need to install following updates
http://www.olympusamerica.com/files/DWPUP4EN.zip
http://www.olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
The software will work with the 32 bit edition of win Vista, not with the 64 bit edition.
Oct 21, 2007 | Olympus VN-960PC
CEN-TECH Digital Scale Logo
80 people viewed this question
Top CEN-TECH Home Experts
john h
Tom Chichester
Are you a CEN-TECH Home Expert? Answer questions, earn points and help others
