Question about Vtech Tote n Go Laptop Plus
Power button doesnt work also no picture - Vtech Tote n Go Laptop Plus
My LG pdp42x3 plasma doesnt turn on.
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 02, 2012 | Cell Phones
Mms failure on iphone 3g. when trying to send picture msg is doesnt complete the looad up and says failure.
Did you just try to restart your iphone by turning it off like this:hold on the home button and the power button,until "slide to power off" appear and then slide to power off.
then turn it on, and try again to send your pic.is it working ?
Sep 25, 2011 | Apple FOR APPLE IPHONE 3Gs PHONE CAR+HOME...
I have a 50 in LCD and am trying to hook up my PS3 to it. All I get is picture, no sound. I have tried holding PS3 button down for 4 seconds and nothing happens, I connected my HDMI cord to PS3 from Tv and...
Ok you should get picture and sound with normal a/v cables. Correct? If so you need to go under settings and switch audio video to hdmi. Another way is if you didnt hold the power button down long enough hold the power button down until you hear it beep twice release and it should pop up menus. Let me know if this doesnt help it could be begining signs of ylod but doesnt sound like it.
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
My acer 5532 touchpad has suddenly stopped working... any ideas? mouse doesnt move and usb wireless mouse doesnt work either.. although it does on myu sister's laptop
Thanks. The Fn F7 idea did not work, the Enable/Disable toggle in Control Panel made no difference BUT the simple pressing of the TINY finger pointing next to the power button DID work. Duh!
Nov 15, 2009 | Acer Computers & Internet
My cannon power shot sd600 viewer doesnt turn on
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD screen on and off to save batteries. You would then use the optical viewfinder in its place. Try pressing this button one more time to see if it turns back on.
Oct 13, 2009 | Canon PowerShot SD600 Digital Camera
G1 phone camera doesnt take pictures
As the others said, there are the two settings. I had a similar problem, then realized how it worked. You need to not press very hard while it focuses first. Then you can press all the way down, if you hold it all the way down, it doesn't recognize that you've already passed the first "Focus" pressure point and gone into the second "Capture" pressure point.
Oct 25, 2008 | HTC G1
Picture mode changes to zoom by itself
It sounds like an eeprom issue. But you can try to reset the set. Turn the set off by the main power on the set. wait a minute or two then together push both the main power button and the standby power button. This should resett the tv. If that doesnt work you will need service as the zoom and the various modes are all controled by the eeprom. Only hold the two buttons for a second. sometimes you will hear the crts discharge while resetting.Hope this helps
Jan 03, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Vtech Tote n Go Laptop Plus Logo
29 people viewed this question
Top Vtech Toys Experts
cloudranger
Level 1 Expert
William Robinson
William Robinson
Are you a Vtech Toy Expert? Answer questions, earn points and help others
