Question about Greenlee Home Fencing
How to add oil on greenlee767 - Greenlee Home Fencing
How to check the oil on a 2001 dyna
Which of the three oils??? For engine :
For cold engine oil level inspection have the motorcycle leaning on its jiffy stand on level ground, pull out the dipstick which is right behind the cam cover and the oil should register between the add and full marks DO NOT add oil if it is at the halfway point from add to full marks on the dipstick. Only add oil when cold if it VERY low. THE warm the engine to operating temperature and then let it idle on the jiffy stand for two minutes on level ground and turn the engine off and check the oil. Add oil only to just below the FULL mark. DO NOT fell over the FULL mark or you may encounter all sorts of problems.
Apr 22, 2014 | 2001 Harley Davidson FXDL Dyna Low Rider
Where do u add lucas oil
Lucas makes all types of additives, if you are using a Lucas oil additive then you add that to your engine oil.Make sure not to over fill the oil,i add this when i change the engine oil. put one less quart of oil and add Lucas. good day
Mar 02, 2012 | 2002 Ford Explorer
Oil dipstick tube broke
look on dip stick you should see cross hatched area with add oil or oil full mark.if you wipe oil dip stick with a clean paper towel and dip stick look dry no sign of oil add little oil at a time see if oil level reach add oil mark or the full mark.if oil is low. low oil light will turn on if bulb is blowed but if dip stick look dry oil level could be low,add little bit at a time dont over fill.
Feb 16, 2012 | Cars & Trucks
It is ok if we put sae 10W- 40 oil for honda oddysey 2004
u should always put in what the car calls for.
Jan 17, 2011 | 2004 Honda Odyssey
When changing the oil on the 2800 psi presher washer were do you add the oil, it looks like there are 3 places to add oil a black cap a gray cap and a red cap.
Normally you would add oil using the same hole that you were using to check the oil which allows the new oil to go into crankcase.
Sep 22, 2010 | Garden
Needing oil
The oil tank on an FXRP is under the seat. Always add oil to the tank when the engine is at operating temp. You can check the oil when it cold and as long as you see oil on the dipstick, it's fine. Start the bike up and warm the engine before add oil though. Check the oil with the bike on the side stand. There are two marks on the dipstick. The upper mark is "FULL HOT" and the lower mark is "FULL COLD". Do not overfill.
Jul 17, 2010 | 1993 Harley Davidson FXR Super Glide
How to check oil and when to add oil
Check oil when oil is warm use a towel the stuffs hot.
Theres a yellow dipstick under the hood located on either side of the engine or on the back side of engine.Pull the dipstick out wipe it clean then check the oil after the oil is warm and the car sits for about 4 minutes not running.Gets all the oil to the pan.Check then if its not to the line on the warm side of the stick add oil. Check oil monthly and change oil every 3,000 miles you can add oil to the oil if low before 3,000 but do not mix two different oils use oil that the truck requires usually it tells you on the cap or inside the hood .
Jan 13, 2010 | 2008 Ford F 250 Super Duty 4WD
When do I add Oil?
Really you should not have to add oil. But to find out have jeep on level surface and use the dip stick to check. Check with car off, pull dip stick out and wipe off and reinsert, Pull back out and read the stick only add if it is low. Do not over fill.
Sep 23, 2009 | Jeep Cherokee Cars & Trucks
Engine rattle noise with oil change light on
Your oil level is low. Wait until the motor is cold and check your oil level. You could also check your level after a drive just shut the motor down and wait 20 minutes for the oil to seep back down out of the block. Pull the dipstick, whipe it clean and did it in again and see what your reading is. If it is between Min and Max towards the middle of both it is fine. If It is all the way up by Max you may have too much, but I bet your oil level is low, I bet when you check it, it will be down near the min mark. If thats the case, find out what type of oil your car uses and buy one quart of oil and add some of it to your motor. I recommend you add about a quarter of the bottle, then stop check the dip stick if still low add a little more. If the level is good then stop. It is critical not to add too much oil. When cars get older they tend to run hot and burn oil. My van does the same thing, I can change the oil and add 5 quarts and about 3 weeks to a month later I have to add a little more and I usually can hear when i need to add some oil because I get a rattle/ping and the idle just doesnt sound right, but once I add the little bit of oil everything is all good.
Jul 09, 2009 | 1999 Oldsmobile Intrigue
Have a Staples SPL-XC200d Paper Shredder. The 'add oil' light is on...but have added oil repeatedly. Does not need more oil. Have also unplugged overnight, thinking that would 'reset' the computer, no...
After you have added the shredder oil, you have to hold down the "Lubricate" button for about 5 seconds. This resets the counter and it will remind you to add oil when you have gone through about 250 more pages. Note: holding down the "Lubricate" button for 5 seconds will reset the counter and make the message disappear whether you add the oil or not, but it is highly recommended that you use the oil.
Apr 23, 2008 | Office Equipment & Supplies
Home Fencing Logo
347 people viewed this question
Top Greenlee Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Greenlee Home Fencing Expert? Answer questions, earn points and help others
