Question about Tablets & eReaders
Proscan plt7801k firmware - Tablets & eReaders
Firmware for proscan plt7100g
The only firmware for the PLT7100G is available here: http://www.proscanvideo.com/item.asp?itemnmbr=PLT7100G . The direct link to the firmware is http://www.curtisint.com/html/custservice/manuals/PRO_PLT7100G_FIRMWARE.ZIP .
Unfortunately, this firmware update may not help with the app problem that you are having.
Jun 02, 2016 | Tablets & eReaders
Will not power up. I Have tried the reset and it still will not help how do i get on it
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 17, 2015 | Tablets & eReaders
My avoca tablet is stuck on avoca loading screen
I have downloaded the firmware and updated my proscan plt8235g tablet but it still stuck on boot screen.
Sep 01, 2014 | Tablets & eReaders
My proscan tablet keeps crashing. It says google play has stoping working. I've reset the tablet twice. what can I do?
Keeps crashing because can't handle too many tasks at one time. I have the same problem. I have the same problem. Try the pin hole reset next to the HDMI input . Press in gently with a paper clip and hold for thirty seconds.
Google play? Try uninstalling updates. Disconnect from internet when not in use.
These tablets have lots of problems not easily solved because there are no firmware updates for this model.
May 25, 2014 | Proscan 10.1-Inch Internet Tablet,...
Proscan PLT8235G stuck on blue screen. Reset button just shuts tablet off, and problem still remains.
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
Apr 02, 2014 | Proscan 8 4GB Android 4.1 Tablet
Proscan 8 inch tablet with android 4.1 jelly bean
Sorry, I have no solution to offer. I am in the same situation and resets aren't working. Wondering if OS is deleted and if so, how to reinstall. So frustrating!
Feb 28, 2014 | Proscan 8 4GB Android 4.1 Tablet
How can I unlock my proscan plt8223g tablet
If you really want the Play store that badly, you can chance turning it into a paperweight by following the steps here: http://forum.xda-developers.com/showthread.php?t=2112562
Make sure you get the correct firmware for this device from manufacturers website instead of the firmware suggested by the guide Different device size but mostly identical hardware.The other steps should work perfectly for the plt8223g.
Nov 17, 2013 | Tablets & eReaders
How to unlock tablet proscan PLT7223G
Download the firmware update PRO_PLT7223G_FIRMWARE.ZIP
Download the RockusbDrivers from https://docs.google.com/file/d/0B_keThrKc71iYkZXMHNxZWdVT0U/edit
Save these files to a new folder on your desktop.
Unzip the FIRMWARE file and follow the instructions. When you need the tablet drivers, manually install the drivers from the RockUSBDrivers files in the new folder you created.
Jul 19, 2013 | Tablets & eReaders
Tablets & eReaders Logo
44 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
