Question about Trendmasters Lost in Space Chrome Robot B 9
New batteries polarity correct, switched on. Still inop..
What is the fuse number for the dashboard lights on a 2007 Ford Focus 3 door hatchback?
Principles of Operation
The instrument cluster and panel illumination consists of dimmable and non-dimmable illumination components. The dimmable illumination is controlled by the instrument panel dimmer switch, which allows the brightness level of the backlights to be adjusted to the customer preferences. With the parking lamps ON, the instrument panel dimmer switch uses electronic circuitry to provide a variable pulse width modulated (PWM) output to the instrument panel and all applicable switches depending on the driver-controlled level of intensity. The headlamp switch backlighting consists of 2 constantly illuminated LED bulbs that are powered by separate circuits. Battery voltage is supplied to the first bulb when the ignition switch is in the RUN position. Battery voltage is supplied to the second bulb with the parking lamps ON. The non-dimmable illumination allows for full intensity dependant on the ignition switch position.
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Instrument panel dimmer switch
  • Circuitry
  • Connector(s)
  • Headlamp switch
  • Illumination source(s)
  1. If an obvious cause for an observed or reported concern is found, correct he cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, verify the symptom and GO to Symptom Chart .
Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The control illumination is inoperative
  • Headlamp switch
  • Circuitry
  • Go To Pinpoint Test A .
  • The instrument cluster illumination is inoperative
  • Circuitry
  • Instrument cluster
  • Go To Pinpoint Test B .
  • The climate control panel illumination is inoperative
  • Circuitry
  • Climate control panel
  • Go To Pinpoint Test C .
  • The audio unit illumination is inoperative
  • Circuitry
  • Audio unit
  • Go To Pinpoint Test D .
  • The transmission control lever illumination is inoperative
  • Circuitry
  • Transmission control lever illumination bulb
  • Go To Pinpoint Test E .
  • The hazard warning switch illumination is inoperative
  • Circuitry
  • Hazard warning switch
  • Go To Pinpoint Test F .
  • The traction control switch illumination is inoperative
  • Circuitry
  • Traction control switch
  • Go To Pinpoint Test G .
  • The window control switch illumination is inoperative
  • Circuitry
  • Window control switch
  • VERIFY the operation of the window control switch in question. If the window control switch is inoperative, REFER to Section 501-11 . If the window control switch operates correctly, INSTALL the new window control switch in question. REFER to Section 501-11 .
  • The instrument panel illumination does not dim
  • Headlamp switch
  • Circuitry
  • Go To Pinpoint Test H .
Pinpoint Test B: The Instrument Cluster Illumination Is Inoperative
Normal Operation A variable pulse width modulated (PWM) voltage is supplied to the instrument cluster through circuit 29S-LA31 (OG/BU). The instrument cluster is grounded through circuit 91-GG14 (BK/OG).
    Possible Causes
  • circuit 29S-LA31 (OG/BU) open
  • circuit 91-GG14 (BK/OG) open
  • instrument cluster
PINPOINT TEST B: THE INSTRUMENT CLUSTER ILLUMINATION IS INOPERATIVE CAUTION: Use the correct probe adaptor(s) when making measurements. Failure to use the correct probe adaptor(s) may damage the connector.
Sep 24, 2017 | Ford Cars & Trucks
Wiper control module location on a 2000 f250
Did you check the wiper relay's in the under hood fuse box ? There are two ,wiper run/park relay & wiper high low relay ! Also ,did you check fuse's ? fuse # 11 - 30amp location cental juction box . The wiper switch is a input to the GEM module . Generic electronic module . The module in most cases isn't the problem ! Learning how to test these electronic systems is , people do not know how to test so they just replace parts . What they should do is take the vehicle to ford certified Technician who has the knowledge and testing equipment to find an fix it .
The generic electronic module (GEM) receives inputs from the following:
  • multifunction switch
  • anti-lock brake control module (vehicle speed signal [VSS])
  • ignition switch
The GEM uses these inputs to control the outputs to the following:
  • windshield wiper high/low relay
  • windshield wiper run/park relay
  • windshield washer relay
  • rear wiper motor relay
  • rear window washer relay
  • GEM Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1240 Wiper Washer Rear Pump Relay Circuit Failure GEM GO to Pinpoint Test K . B1241 Wiper Washer Rear Pump Relay Circuit Short to Battery + GEM GO to Pinpoint Test K . B1342 ECU is Defective GEM CLEAR the DTCs. REPEAT the GEM self-test. If DTC B1342 is retrieved, INSTALL a new GEM. REFER to Section 419-10 . B1431 Wiper Brake/Run Relay Circuit Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If the windshield wipers stay on continuously, GO to Pinpoint Test C . B1432 Wiper Brake/Run Relay Circuit Short to Battery GEM GO to Pinpoint Test B . B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure GEM GO to Pinpoint Test D . B1436 Wiper Hi/Low Speed Relay Coil Circuit Short to Battery GEM GO to Pinpoint Test D . B1438 Wiper Mode Select Switch Circuit Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If both the windshield and rear window wipers are inoperative, GO to Pinpoint Test L . B1441 Wiper Mode Select Switch Circuit Short to Ground GEM GO to Pinpoint Test C . B1446 Wiper Park Sense Circuit Failure GEM If the intermittent windshield wiper speed does not operate correctly, GO to Pinpoint Test E .
    If the speed dependent interval mode does not operate correctly, GO to Pinpoint Test G .
    If both windshield and rear wipers are inoperative, GO to Pinpoint Test L . B1450 Wiper Wash/Delay Switch Circuit Failure GEM If the intermittent windshield wiper speed does not operate correctly, GO to Pinpoint Test E .
    If the wash and wipe function does not operate correctly, GO to Pinpoint Test F .
    If both the windshield and rear wipers are inoperative, GO to Pinpoint Test L . B1453 Wiper Wash/Delay Switch Circuit Short to Ground GEM If the windshield wipers stay on continuously, GO to Pinpoint Test C .
    If the wash and wipe function does not operate correctly, GO to Pinpoint Test F . B1458 Wiper Washer Pump Motor Relay Circuit Failure GEM GO to Pinpoint Test F . B1460 Wiper Washer Pump Motor Relay Coil Circuit Short to Battery GEM GO to Pinpoint Test F . B1473 Wiper Low Speed Circuit Motor Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If the windshield wipers do not operate at high or low speed correctly, GO to Pinpoint Test D .
    If the intermittent windshield wiper speed does not operate correctly, GO to Pinpoint Test E . B1475 Accessory Delay Relay Contact Short to Battery GEM REFER to Section 501-11 . B1476 Wiper High Speed Circuit Motor Failure GEM If the windshield wipers are inoperative, GO to Pinpoint Test B .
    If the intermittent windshield wiper does not operate correctly, GO to Pinpoint Test E . B1611 Rear Wiper Mode Switch Circuit Failure GEM GO to Pinpoint Test H . B1614 Rear Wiper Mode Switch Circuit Short to Ground GEM GO to Pinpoint Test I . B1820 Rear Wiper Motor Up Relay Circuit Short to Battery + GEM GO to Pinpoint Test H . B1839 Rear Wiper Motor Circuit Failure GEM GO to Pinpoint Test H . - All other DTCs. GEM REFER to Section 419-10
Jun 06, 2017 | Ford F-250 Cars & Trucks
How do I change the battery
  • Open battery compartment
  • Note battery polarity, then remove
  • Install new battery with correct polarity
  • Close battery compartment
Aug 12, 2016 | Cameras
I want to take out the high beem fuse for a 2003 buick regal... I lost the car manual
Two fuses HDLP L fuse #36 15amp & HDLP R fuse #32 15amp ,located in the under hood fuse / relay box. One is for Left - low an high beams an the other is for right side low an high beams . What's wrong , no high beams ?
Headlamps Inoperative - High Beams
Did you perform the Lighting System Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Lighting Systems
  1. Turn the ignition to the OFF position.
  2. Turn the headlamp switch to the HEAD position.
  3. Place the headlamp dimmer switch in the high beam position.
Are the high beam headlamps operating properly?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
yes Go to Step 3
Is only one high beam headlamp inoperative?
yes Go to Step 7
Go to Step 4
Place the headlamp dimmer switch in the flash to pass position.
Do the high beam headlamps operate in the flash to pass position?
Go to Step 13 yes
Go to Step 5 no
5
Does the high beam indicator illuminate?
Go to Step 12
Go to Step 6
6
Test for a high resistance, an open or a short to battery positive voltage in the high beam signal circuit of the headlamp dimmer switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 17
Go to Step 13
7
  1. Disconnect the inoperative headlamp.
  2. Using a test lamp connected to ground, probe the battery positive voltage circuit of the inoperative high beam headlamp.
Does the test lamp illuminate?
Go to Step 8
Go to Step 9
8
Connect a test lamp between the headlamp high beam signal circuit and the battery positive voltage circuit of the inoperative high beam headlamp.
Go to Step 11
Go to Step 10
9
Test for a high resistance or an open in the battery positive voltage circuit of the inoperative headlamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 17
Go to Step 12
10
Test for a high resistance or an open in the headlamp high beam signal circuit of the inoperative high beam headlamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 17
Go to Step 12
11
Inspect for poor connections at the harness connector of the inoperative headlamp. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 17
Go to Step 14
12
Inspect for poor connections at the harness connector of the fuse block - underhood. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 17
Go to Step 15
13
Inspect for poor connections at the harness connector of the headlamp dimmer switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 17
Go to Step 16
14
Replace the inoperative headlamp. Refer to Headlamp Assembly or Headlamp Bulb and/or Cornering, Sidemarker, Park, Turn Signal Bulb Replacement .
Did you complete the repair?
Go to Step 17
15
Replace the fuse block - underhood. Refer to Underhood Electrical Center or Junction Block Replacement in Wiring Systems.
Go to Step 17
16
Replace the headlamp dimmer switch. Refer to Turn Signal Multifunction Switch Replacement in Steering Wheel and Column.
Go to Step 17
17
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Jan 07, 2016 | Buick Cars & Trucks
White screen and not switching on and not charging
Did you replace the battery with a new battery, or one known to be good? With the CORRECT battery? If the new battery's polarity is opposite the original battery, you probably destroyed the phone. The same thing may have also destroyed the charger.
Feb 02, 2014 | ahappydeal Cubot C9 Android 2.3 Smartphone...
Right head phone in op
It looks like you will need to open them up and look for a loose wire in both earpieces. Also, while there, check to see if the batteries are in correctly relating to polarity!
Jan 15, 2013 | Rocketfish Rf-rbwhp01 Wireless Headphones,...
I have an 89 probe that the battery switches polarity
If you switch the battery polarity correct it. You wil have fusable link that has opened. Go to the engine juction fuse box right near the battery and inspect for open fuse and replace with the same amperage . You also stated switches polarity so this means you have a volt meter so use the voltmeter to test each of your fuses
Feb 24, 2012 | 1991 Ford Probe
Power mirrors, driver power seat, adjustable pedals all don't work... checked fuses and all ok... Any suggestions?
it sounds like the driver seat module. It controls all of these items.
buy used at car-part.com. look on page with * for lowest price.
buy new at discount at tascafordparts.com
  • The memory mirror is inoperative
  • Driver seat module (DSM).
  • Circuitry.
  • CJB fuse 3 (7.5A).
  • Exterior mirror motor.
  • Mirror control switch.
  • The memory seat is inoperative
  • Circuitry.
  • Seat control switch.
  • Seat track.
  • DSM.
  • PDJB Fuse 109 (30A).
  • Power seat motor.
  • Adjustable brake pedal does not operate correctly — does not operate using the adjustable pedal switch
  • Battery junction box (BJB) fuses:
    • 109 (30A).
  • Circuitry.
  • Switch.
  • Adjustable pedal motor.
  • Driver Seat Module (DSM
Oct 02, 2009 | 2003 Ford Expedition
Rear side windows
This may be just a case of inadvertently hitting the window lock out n th driver door window switch by mistake. Check that first. Here's some background on window operation
The driver power window regulator motor is controlled directly by the master window/door lock/unlock switch (and its integrated "auto down" module). Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The driver power window regulator motor is a reversible motor that is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The passenger power window regulator motor is controlled directly by the passenger power window switch and can also be controlled by the master window/door lock/unlock switch. Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The passenger power window regulator motor is a reversible motor, which is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The power rear quarter glass is also directly controlled by the master window/door lock/unlock switch. The power rear quarter glass power latches also utilize reversible motors. The power rear quarter glass power latches are operated by applying power and ground to the motor leads to open the window, and then reversing polarity on those same leads to close the window.
  • All windows are inoperative
  • BJB Fuse:
    • F20.
  • Circuit.
  • Power window relay.
  • Front door power window switch.
  • GO to Pinpoint Test A .
  • Single power window is inoperative
  • Front door power window regulator.
  • Circuit.
  • Driver door power window switch.
  • GO to Pinpoint Test B .
  • Vent power window is inoperative — quarter window glass power latch
  • Circuit.
  • Quarter window glass switch.
  • Quarter window glass power latch.
  • GO to Pinpoint Test C .
  • The one touch down feature is inoperative
  • Master window regulator and door lock switch.
  • INSTALL a new master window/door lock/unlock switch. REFER to Switch—Master Window Door Lock/Unlock .
  • The back window will not defrost
  • CJB Fuses:
    • F30 (10A).
    • F32 (20A).
    • F34 (20A).
  • BJB Fuse:
    • F27 (45A)
  • Circuit.
  • Heated back window switch.
  • SEC/timer module.
  • Rear window defrost relay.
  • GO to Pinpoint Test D .
  • The back window defrost will not shut off automatically
  • SEC/timer module.
  • Circuit.
  • GO to Pinpoint Test E .
Jan 28, 2009 | 1999 Mercury Villager
Cooling fan inop
check if the sensor is driving the correct polarity cause this is an electrical supply fault your fan is ok try to check the polarity using a multimeter device
Oct 30, 2008 | 1996 Nissan Altima
Trendmasters Lost in Space Chrome Robot B 9 Logo
24 people viewed this question
Top Trendmasters Toys Experts
ray gallant
Are you a Trendmasters Toy Expert? Answer questions, earn points and help others
