Question about Maytag Atlantis MAV6000 Top Load Washer
Can't get anything but warm of hot water
In these economic times want to save by washing cold!
  • 1,543 Answers
If you set the washer for cold wash with a cold rinse, no hot or warm should enter the machine. If any hot or warm enters machine on cold / cold, check to see if the hot and cold hoses are hooked up correctly, and not reversed.
Posted on Jun 14, 2009
Is it more economical to connect both taps hot and cold or connect cold only and have the machine heat the water
JMHO, but guessing it's probably better to connect hot water to the DW. It could be taxing on the DW to heat cold water every time. At least with hot water available, the DW wouldn't have to work so hard and maybe your DW will last longer--or at least the heating element probably would. Can't imagine the cost of using pre-heated water (from a hot water heater) would be extravagant as a DW probably doesn't use that much water each time.
Mar 19, 2016 | Washing Machines
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
My Inglis washer machine (#111-07) which we bought 2 weeks ago, doesn't use any hot water when set to the warm cycle (in between cold and hot), so i can only wash with entirely cold or superhot water...
Hi Elllie602 (!) from retired Englishman in SW France,
2 weeks old? Under guarantee/warantee? Get in touch with the vendor/shop!!!
Even if it takes only cold water for the warm wash (which is a bit daft- normally washers mix the hot and cold accordingly) and heats it, that is not how most hot n' cold washers work.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 21, 2011 | Whirlpool Washing Machines
Can you wash in cold water only
Yes , you can look into the program and find an easy economical quick wash which will has a fast wash with cold water, rinse and short drying cycle.
The normal/regular wash uses the heater as with warm water the dirt comes off well and is sterilised wheras in cold wash the average dirt might go off but not as clean as in a hot wash.
So you can use the programs as required for the clothes in question.
Aug 21, 2010 | Whirlpool AWM6120 Front Load Washer
Cold Water extremely slow to fill. Had same problem with hot water some time ago and I have turned hot water off at tap and always choose cold water. Now I have turned hot water tap back on and use warm...
sounds like both valves r faulty .try cleaning inlet hose filters and if that doest work must b valves. buy and change cold first to save u money,if u dont use warm often.please reply 4 more help.p/s turn off power b4 working on unit dont want any acciedents.
Apr 08, 2010 | Fisher and Paykel (IWL12)
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Water changes from hot to cold. Valves checked out
Bad thermistor or bad board. Or its just a energy super saver and it will not let you use all that hot water. Did it work before or its been like this since new? New energy star models will only let it just get warm for hot wash, saving energy. warm wash is like 70 deg water.
Nov 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Water is not hot enough
What a great energy saver response....run water through another tap in the house in order to fill the pipes with hot water! I have the same problem; cannot even get WARM water in my tub. I have 2 solutions: #1, on my incoming water pipes are regular faucet handles which I am going to attach a hose on the hot side that will reach into the washer and manually mix the temperature. #2, purchase an old refurb washer at a used appliance store that HAS a hot-water setting and hope they will take the "wonderful, new energy saver" as a trade. There are just some times you really need HOT water. I can't imagine washing diapers in cold, although I haven't had to do that in many years. Energy saving factory settings: capital "B", capital "S"!!!
Mar 30, 2009 | Washing Machines
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Atlantis MAV6000 Top Load Washer Logo
129 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
