Question about House Brand Black Hitachi Touro Desk Pro HTOLDNB30001BBB 3TB USB 3.0 3.5in External Hard Dri
Ac adaptor hitachi desk pro HTOLDNB30001BBB - House Brand Black Hitachi Touro Desk Pro HTOLDNB30001BBB 3TB USB 3.0 3.5in External Hard Dri
Power supply specs Hitachi Lifestudio Desk Plus
Hitachi Lifestudio Desk Plus Hlsdpub10001bbb 1TB Drive and original AC adapter have been separated. Need to know Adapter output Voltage/amperage identify original or acceptable replacement.
Sep 17, 2013 | Hitachi Lifestudio Desk Plus...
Hitachi touro usb 3 hardrive will not work in windows 8
I contacted Hitachi support, no solution. They say we should return and exchange the disk with a new model that supports Windows 8.
Very very fustrating.
Jan 23, 2013 | Hitachi Gst Hitachi - Touro Desk Pro USB...
Im looking for ac adaptor for dvdcam,hitachi dz-bx31e,
Adapters are available thru partstore.com for your model. I hope this helps.
Sep 06, 2010 | Hitachi DZ-BX31E DVD Camcorder
I Need a new AC/DC Adaptor for Shark Sewing Machine Model 998A
Call Euro-pro at 1-800-798-7395, they are the main company for Shark.
Jul 27, 2010 | Euro-Pro Shark 60 - 384
Can you charge a lap top thru usb port on a desk top
Hi guest, you cannot charge the laptop thru usb, it will be solely on the AC adaptor port. USB's are functioned for multi-media devices such as cameras, MP3 players, etc..
May 15, 2010 | Computers & Internet
Laptop keeps turning off why?
This could be due to overheating. If you have ever taken a laptop apart then you will have seen that on most laptops the cooling fan draws in air via a grill and then blows this air around the CPU and exhausts to the outside world again. This air is NOT circulated around the rest of laptop case to dissipate heat.
You can try these steps
1. Check your power chord, socket, UPS, everything that leads from the electrical network to your AC power adaptor, but don't forget to check your BIOS settings and software setup, because it's probably your adapter who's sensing an overload of power drain
2. In most cases, an overheating processor due to a build of internal dust is the cause for random reboots or turn offs.
3. AC power adaptor not able to sustain normal power needs (faulty power adaptor) - take care of the same items as those I mentioned at 1.
4. Especially with older laptops, the battery may overheat, simply due to internal battery fault, or charging levels.
5. If you have a new laptop, be sure to have all ventilation openings free, and when used on a desk, try not to allow full contact with the surface - use a book or two to keep the laptop above the desk and have some space beneath it.
Regards
Aug 11, 2009 | Computers & Internet
Hitachi Desk star 500GB SATA drive
you can check the jumper, is it on the right place?
besides, some motherboard is indeed do not support hard drive with large size on it...
Jun 08, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Laptop AC Adaptor
look here the problem can be of two types,,first the problem can be of the adapter or the port in the computer where the adapter pluggs in the computer,,look for any friends or relatives using the same computer with the same good adapter,,plugg it into the computer,,if u dnt c the problem then prob with the adapter or else prob with motherboard
best of luck,,keep me posted,,giv agood rating
May 26, 2009 | Dell Inspiron 6000 Notebook
I have lost the ac adaptor for my Hitachi Cam DZ-MV730A
I may be able to help you - I have an extra adaptor (for charging the battery) but not the AC cord or camera connection. Is this what you need?
Dec 17, 2008 | Hitachi DZ-MV730A DVD Camcorder
House Brand Black Hitachi Touro Desk Pro HTOLDNB30001BBB 3TB USB 3.0 3.5in External Hard Dri Logo
26 people viewed this question
Top House Brand Computers & Internet Experts
David Payne
David Payne
Are you a House Brand Computer and Internet Expert? Answer questions, earn points and help others
