Question about Thermador CVS30R Kitchen Hood
Dacor downdraft going up and down - Thermador CVS30R Kitchen Hood
Jxb37 won't lower
My unit always goes up. Sometimes it doesn't go down. Then, after some time it goes down. Could it be the capacitor is bad?
Mar 10, 2014 | GE Profile JVB67HWW 36" Telescopic...
Downdraft up and down
Hi do you mean the air is increasing and decreasing on its own
Feb 22, 2008 | Thermador CVS30R Kitchen Hood
The vent downdraft keeps going up and down
This means that one of the limit switches by the motor has failed.
Apr 22, 2011 | Thermador UCV36A 36" Universal Cook 'n'...
We have a tempstar down draft furnace. 2 years ago the heat exchangers where replace because we were told they were cracked. This year the downdraft motor was makikg a lot of noise & we were told the...
Sounds like the low limit or high limit is out these control the fan motor.They are usually set to kick on around 150 degrees and set to go off around 95 to 100 degrees. Over heating does happen with cracked heat exchangers and it can possibly take these two items out. Normally your furnace should run approximately five minutes or a little less then your fan motor comes on and then for cooling down burners should drop and the fan motor should run again roughly five minutes or so then shut down. Times may vary as to your settings.
Dec 20, 2010 | Heating & Cooling
I have a Dacor downdraft vent RVxx. I find that 2
I just unplugged it again and replugged it. Now it works. Thanks! Renee
Jun 13, 2009 | Dacor Preference RV36 Kitchen Hood
YOU WILL NEED TO CONTACT A AUTHORIZED DACOR DEALER OR PARTS DISTRIBUTOR I SUGGEST CALLING FOX APPLIANCE IN ATLANTA GA OR THE MFG IN BERKLEY ,CA
May 26, 2008 | Kitchen Ranges
Call Dacor at 800 793 0093. They'll tell you who has the part.
Dec 03, 2007 | Dacor RV36SS Kitchen Hood
Downdraft doesn't alway go down and up.
I have the same problem. Seems to be pretty common that the motor that raises the unit goes bad. Ours is 2 1/2 years old and has not seen that much use....that motor should not have failed that soon...and this is a high end product!!! I have been quoted $289 for a replacement motor and $150 for labor!! So, $450 bucks....gads. The unit, new, cost about $900, as I recall.
May 08, 2007 | Thermador UCV36ASS Kitchen Hood
DACOR DOWNDRAFT RV36B PROBLEM
when just the high and low lights are lit, the unit is in childproof mode. try holding down the high and low buttons at the same time until they go out. then if they do, check the response of the other buttons. If this dosen't help, there are really only 2 other options. Most often we see the control board go bad on these (located behind an access panel in the lower right hand corner of the unit below the counter) or the button pad contacts wear out. If the only button that doesn't respond is the up down button, and all the other buttons work fairly easily once its up..then you probably have a bad button pad. If the thing does all sorts of weird things and seem to have a mind of its own, probably a bad control board. the control boards on these fail so often, they re-designed the board to prevent further failures. The button pad is easier to replace and cheaper, so if you have to guess go with that first. good luck!
Jan 01, 2007 | Dacor Prefrence PRV36 Stainless Steel...
Thermador CVS30R Kitchen Hood Logo
126 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
