Question about Haier HVT12ABS Compact Wine Cooler
Need to buy thermostate - Haier HVT12ABS Compact Wine Cooler
My dryer dose not get hot i no there are two thermostates iwant to change tih right one
Most probably the heater itself is burnt. If you have an instrument to check, better before start to buy some parts which you will not need.
Sep 10, 2017 | Cars & Trucks
Where to buy refrigerator thermostate
I do buy them in the Handy man. Not even sure there is a handyman close to you.
You also could try to google the brand and type of the thermostat and click on where to buy (close to you and not close to me)
Aug 25, 2014 | Frigidaire Refrigerators
Where can I get instructions for thermostat replacement in Tefal FV8225 steam iron
I suggest to remove the bad thermostate and try to buy a similar one. First remove the scew which fix the thermostate on the iron base. Then carefully disconnect the two wires and mark them in order to connect correctly the new one. I used to make a litlle sketch.
But before buying a new thermostate, you should test the thermic fuse (a small component placed into a thermic "sleeve" and fixed with a small brace screwed to the base) as when the thermostate jams this fuse burns out, giving a second protection.
Jun 18, 2012 | Irons
MY A/C WORKS PROPERLY HOEVER THE HEATING SYSTEM IS NOT WORKING. AIR COMES OUT BUT IT'S COLD. WHAT SHOULD I BE LOOKING INTO?
a stuck or broken thermostate would do that if the moter temp takes a really long time to warm up the thermostate is stuck open and needs to be replaced if the moter warms up to fast or over heats the thermostate is stuck shut and needs to be repalced. the heater core its self could be plugged and may be fixed by back flushing with water if you do it your self flushit seperate from the moter to prevent what ever may have plugged it from re-entering it.
Oct 14, 2010 | 2004 Ford Windstar
My power switch broke and need to get a new one. Does onyone know where i could purchase a new thermostate switch or should i throw it away?
If your talking about the thermostat you will have to throw it away. You can buy one at any Lowe's, Lumber Yard or Home Depot.
Jan 02, 2010 | DeLonghi Heating & Cooling
Over heating
The water pump has what's called a 'weeping hole' built into it. If the pump is bad You'll se water coming out of the hole. When was the last time you flushed the radiator? It may be your radiator cap is bad, they should be changed once a year & the radiator flushed. You can also test ur thermostate. take out ur thermostate & put it in a pot of water so that the water covers the thermostate. Then put a cooking thermometer in the pot to & heat the water til it says 195. u should see the car thermostate begin to open. if it don't it's bad & needs replacing.
Sep 22, 2009 | 1995 Volvo 850
The buttons on my duo therm thermostata not responding
there is a one somal swicth in thermostate you put there (WD40)and trun back and farwead then bring same place
Jul 18, 2009 | Dometic Rooftop RV Air Conditioner
No power to thermostate on Duo Therm 15000
Look for a small fuse somewhere in the control panel. Usually a blade type (car) fuse 3 to 5 amp. Chack to see if its blown. If you have no fuse, or its NOT blown. Check to see if you have voltage comming out of, and going into the transformer.
Thsi is where you would START to diagnose the problem. Check this and we can go further.
Jan 18, 2009 | Dometic Rooftop RV Air Conditioner
How to change out thermostat in 1991 buck centry 3300
your thermostate is probably on the block sideways in whitch case you need to remove the air filter outr of your way and loosen the clamp on the thermostate housing. from there take out the 3 bolts holding the thermostat housing in place and remove it. Caution water/antifreeze will come out. take the thermostate out watching where the gasket has been placed and install the new one after cleaning the suface of the old gasket. sometimes it is good to use indian head gasket sealer. there will be 2 bolts on top and 1 bolt on the bottom under the housing. install the new thermostate tightn the hose replace your filter and fill the over flow resivor only to the point on COLD MAX. take the cap off the radiator start the car wait for the thermostate to open and fill the raditor the rest the way up. if it starts to boil over just shut the car off and let it cool than add more water *** needed...
Aug 01, 2008 | 1991 Buick Century
Service problem
This code is a fuzing unit code , one of your thermosters are busted or dirty so it is not picking up the heat correctly , ill sugest you take out the fuzing unit and clean both thermosters and try again , but you need to reset the code after cleaning the thermosters by pressing :yellow c 107 and hold down orange c until it shows copy sp mode press 1 # then turn the power switch on and of hope this helps
Nov 05, 2007 | Ricoh Aficio 2020 All-In-One Laser Printer
Haier HVT12ABS Compact Wine Cooler Logo
19 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
