Question about HP Pavilion MX70 17" CRT Monitor
My hp pavilion mx70 is running so slow
What should I do? I now have the HugesNet Internet system and I hate it! What can I do to make my computer run fast? Is there a virus or something on my computer?
    Scholar:
  • 28 Answers
The issue can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try the solution: http://www.speeduphp.com/fix-slow-hp.html
Meanwhile, upgrading hardware configuration (add RAM, change a new video card, larger-volume HDD etc) can be a fast yet effective way to improve your pc performance. But that won't be the most economical way, as you know you can't always afford to do that.
Posted on Jun 20, 2012
  • 24 Answers
You could have a virus, spyware or a registry problem. You should scan for all three. More info on registry repair and speeding up a slow computer can be found here
Posted on Jun 23, 2009
When I select a movie the small circle just keeps running and movie never starts
Computer needs a cleaning or it is your internet connection or provider. Go and check your internet speed by typing Internet speed test in your browser and test to see how fast or slow your internet is running. If the internet is slow it will most likely run movies slow online and we call this buffering witch we all hate but it is do to slow computer or an upgrade needs to be done threw your internet provider.. Good luck hope this helped....
Mar 10, 2018 | The Computers & Internet
Slow internet speed with hp pavilion, windows 8, internet explorer 10
My suggestion to remove both McAfee and Norton, they slow down the PC to a crawl. Also they bring all sorts of toolbars and unwantedness.
The free and light use antivirus is the one built into Windows, or if you are rocking Windows 7, Microsoft security essentials. Another one would be malwarebytes as a second layer of defense.
Dec 28, 2012 | HP Pavilion Computers & Internet
Slow shutdown HP Pavilion dv7
There are a number of reasons that may causing your HP computer running slow to shut down or start up, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/ to free detect and fix related issues. Regards!
Jan 31, 2012 | HP Pavilion dv7-1132nr Notebook PC
I have an hp pavilion a720n desktop with an hp pavilion mx70 monitor and windows xp home. There is a problem with the color displayed on the monitor. I see mainly black and white, but blue shows up fine....
First of all you can check the computer by connecting another monitor to it to see if the problem goes away...if so then the problem would be in the monitor. If not , then I would try to change the video grafics card in the computer(assuming you don't have built in video). If you have built in video on the mother board then you will either need to replace the motherboard or disable the onboard video and install a video card
Dec 19, 2010 | HP Pavilion MX70 17" CRT Monitor
HP Pavilion dv7 goes into sleep while im gaming what could the problem be? overheating?
Hi, Click on start, controlpanel, power options, advanced and check your settings there. But depending what support you have inside the computer gaming could be too much.
Feb 06, 2010 | HP Pavilion MX70 17" CRT Monitor
My color monitor (hp pavilion mx70) is having graphics problems
Need to download correct graphics drivers and then you will be able to change the options. If you already have up to date drivers then you need to Right Click on desktop and select properties and then click on the Settings Tab and change it from 16 color to Highest (32 bit). Oh, go to manufacturers web site to download drivers.
Jun 30, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor won't come on right away
Sounds like the CRT is starting to go bad cause its taking longer and longer for it to boot up. CRT's aren't available now so a new monitor would be the only option.
Apr 09, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor is missing pins?
If the monitor is working correctly, there is no problem. Not all 15 pins are used, therefore there is usually two missing.
Jan 24, 2009 | HP Pavilion MX70 17" CRT Monitor
McAfee not installing
What you need to do is buy additional memory and install it.
Whats happening is that the memory installed is not enough to run all the applications on your computer. In order, to properly run any more applications (programs) its the only thing you can do or remove the programs you don't need.
Hope this helps. Bud
Jan 08, 2009 | HP Pavilion MX70 17" CRT Monitor
Possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
HP Pavilion MX70 17" CRT Monitor Logo
172 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
