Question about Samsung TX-P2730 TV
Circcuit board cracked need schematic for TXP2730
I need wiring schematics for 2006 yamaha xt 225
If you have no spark at your plug, check your spark plug lead. Make sure it isn't broken or cracked. Check the wires from your coil make sure they aren't broken or cracked or have rusted connections. Scroll down this page and you will find a wiring diagram.
Aug 06, 2014 | 2006 Yamaha XT 225
Need schematic for Main board for HP photosmart 1215 printer
HP doesn't give out board schematics. If you need the board repaired try www.hytec.com.
May 21, 2014 | HP PhotoSmart 1215 InkJet Printer
U778K
The first thing I would do is to make sure your power supply is good. I have found that sometimes they will make some of the lights come on, but they may have 12V and not 5V or whatever. I bought a small thing you plug the power supplies into, and then the lights light up to show you if the power supply is supplying what it should. Once you are sure the power supply is good, (don't assume) if they still don't work, I would visually check the boards. I have found many times the small capacitors go bad. After replacing them, the boards worked fine. Usually they will have the top cracked open or bubbled up. If you are up on electronics, as I guess you are if you know how to read a schematic, soldering in new ones is a simple matter. I also remove the CPU, clean the bottom surface off, and put a small amount of CPU grease on and reinstall the CPU. Be sure to check all the pins, as they are pretty small and easy to bend one over.
Jan 01, 2018 | Intel Motherboard
WS 55511 MITSUBISHI HAD POWER OUTAGE , FIXYA TOLD ME TO UNHOOK FRONT PANELTV WORKED GREAT . ANOTHER POWER OUTAGE FIXYA PRO DAID REPLACE 7CAPS &PICOS WHICH IHAVE TWICE. IM A PRETTY GOOD...
Hi William,
If your problem is a continuous green blinking led light and will not turn on, this is an indication that the DM of your unit try but hasn't booted up and stuck to this fault.
If you have checked fine the fuses on the DM power supply board, you have to check/replaced also the electrolytic capacitors on that board.
www.tvrepairkits.com has a repair kit for your unit (DM power supply board) that includes these parts.
If you've already replaced the capacitors on that board but still the symptoms still persist, I would advice you to check/replaced the capacitors on the power supply board feeding the DM power supply board. Check also the pico fuses and bad solder joints (cracked, cold, dried solder). Resolder the joints that look suspicious.
Yes, your model has no complete schematic diagram downloadable online. I have a copy of the repair manual that includes the schematic but not a complete one. The power supply's schematic shows only the major parts and the output voltages of the board. Same as on the DM's power supply.
Email me at jimvincentvillanueva@yahoo.com, I will send you the copy of the repair manual.
Jdvillanueva
Oct 31, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The middle button of my motorola wont work
dismantle and service that faulty button. Use PENCIL (as a source of carbon, because carbon is an electrical cunductor), Scrap the end of the button with that sharp pencil also the "circcuit" involved.
Jul 24, 2011 | Cell Phones
I need the schematics for a Marshall MG-10KK guitar amplifier in order to repair it! I'm a good technician but I don't speak english very well... rsrs Thanks!
Most of the problems with the small guitar amps are blown power amp chips. They usually use chips like the TDA2030 which look like a power transistor.
Most other problems involve broken connectors, bad solder joints or cracked circuit boards. The power supply area is so simple one doesn't need a schematic for that part which is usually just three terminal regulators for +/-15 volts. Schematics are often hard to find.
Try this site, although this is a different model, much of the schematic will likely be the same.
http://elektrotanya.com/marshall_valvestate10_10w_8001_8010.pdf/download.html
Nov 17, 2010 | Marshall 15 Watt Guitar Amp
Kenwood KRF-V5200D, will not turn on. I'm getting 240V in, but only geting 900mV at the pins to Transformer CN201. Apparently it was dropped, the height was 1/2 to 1 foot. Is there a schematic diagram...
Unfortunately, I do not have a schematic diagram. However, having delt with these kinds of problems on TVs, stereos, VCRs, etc., I would say, over 90% of the time, you won't need a schematic to figure out the problem. Chances are that a solder joint slightly cracked, and possibly broke a trace. I would inspect the circuit boards carefully, especially the legs of the transformers, relays, and capacitors. Unless you can find another owner, the schematics are usually hard to find, and when you do, they can be expensive, so I would try spotting some physical damage before expending the money for a schematic. You only need them maybe once every 10 or 20 years on these machines, normally. Good luck, hope you can see and fix the problem!
Apr 27, 2010 | Kenwood Audio Players & Recorders
Speedomidor not responding
the problem is in the sending unit at the trans mission or your gauge is malfuntioning you can replace these quite easily. the fuse by the way only controls the whole cluster and not just the seperate componates....note... becareful when you remove the gauge from the cluster, if you have clothing on that gets a static charge easily and this discharges while handling the circcuit board you will fry the whole board and that is a very expensive replacement....please rate this...thanks
Sep 01, 2008 | 2004 GMC Envoy
Sony playstation
http://manuals.playstation.net/document/en/psp/current/photo/mscopy.html
Jan 03, 2008 | Sony PlayStation Portable (PSP) Console
Televison & Video Logo
15 people viewed this question
Jerry Greenberg
Jerry Greenberg
