Question about Lucchese Classics L1188.64 Mens Full Quill Ostrich Boots
L118 has no light or power
My L118 has no power after the battery no power to switch or lights
Poulan pb1638lt lights don't work
hi mate, i am going to assume you have checked the globes :) other then that below is the manual, there appears to be a note on the wiring diagram about the headlights see below:
NOTE YOUR TRACTOR IS EQUIPPED WITH A SPECIAL ALTERNATOR SYSTEM. THE LIGHTS ARE NOT CONNECTED TO THE BATTERY, BUT HAVE THEIR OWN ELECTRICAL SOURCE. BECAUSE OF THIS, THE BRIGHTNESS OF THE LIGHTS WILL CHANGE WITH ENGINE SPEED. AT IDLE THE LIGHTS WILL DIM. AS THE ENGINE IS SPEEDED UP, THE LIGHTS WILL BECOME THEIR BRIGHTEST.
basically the lights run directly off the alternator with a switch in between,
before you proceed : if you know how to test power and earth wires with a test light then i would look at the attached diagram, if your not familiar with test lights and testing for power and earth then i would call a mate who can help
with the mower running i would use a simple light tester ( one that just lights up when there voltage) test and see if there is power to power side of the light bulb socket when the switch is on ( the red wire), if theirs no power at the light bulb socket then try the same test on each terminal of the headlight switch
if there is power at the light bulb socket - then check the earth wire is connected ( the back wire connecting to the light bulb socket) or replace the bulbs :) if not proceed to test the switch below
if there is power one one side of the switch but its not going to the bulbs - replace the switch, or ensure the wire that goes from the switch to the bulb is connected as there is a joiner in between that could be unplugged or corroded
if there is now power to the switch or the bulb at all then your alternator my be faulty and not providing power to the bulbs, your mower could just be running and starting off the remaining charge in the battery as the lights dont connect to the battery they will not function even if the battery is charged
see below for link to the manual with wire diagram
http://www.poulan.com/ddoc/POUI/POUI2006_USen/POUI2006_USen_401536_.pdf
Apr 19, 2017 | The Computers & Internet
I need a diagram for a 2001 VW Cabrio relay. I thought number 6 was for the blinkers/hazards but it's not and its empty. 413 is in there and blinkers and hazards just stopped one day. I don't know if I...
A2Resource
a great vw resource site
Relays:
Num.Relay Arrangement and Pinout (with control number stamped on relay)
1A/C Relay (13 or 140)
1A/C Switch
2Radiator Cooling Fan
3Fan Switch High Speed
4Battery, Fuse 23
5A/C Clutch (via pressure and temperature switches)
6Main Fusebox Battery Power, Fuse 19
7Main Fusebox Ground
8Fresh Air Fan
2Rear Wiper Relay (72)
1Main Fusebox Ground
2Main Fusebox Run Power, Fuse 4
3Rear Wiper Motor
4Wipe/Wash Signal from Switch
3Digifant Control Unit (30 or 32), Motronic OBD1 Control Unit (109)
2Tachometer
3Main Fusebox Start/Run Power
4Main Fusebox Battery Power
5To ECU (relay ) (1990 G60, ABA/VR6 OBD1 only)
6To ECU and Engine Electronics
4Load Reduction Relay (18)
1From Ignition Switch Run Power
2To Main Fuse Box Run Power
3Main Fusebox Battery Power
4Main Fusebox Ground
5Low Coolant Level Control Unit (43)
1Main Fusebox Start/Run Power
2Low Coolant Level Sensor
3Coolant Temperature Sensor, Gauge
6Flashers (21)
2Flasher Output
3Flasher Input/Power
4X/6 (Trailer Light)
7Headlight Washer (33)
1Main Fusebox Ground (B/4 to C/3 to Ground)
2Headlight Washer Pump
3Headlight Switch Pin 56 (headlights) (B3 to D4 to light power)
4Main Fusebox Battery Power (B/5 to Y/2)
5Windshield Washer Pump (B/1 to B/2 to washer pump power)
8Wash/Wipe/Intermittent Relay (19 for standard relay, 99 for variable intermittent module)
2Intermittent Switch
3Main Fusebox Run Power, Fuse 5
4Park/Low Signal (ground when parked, positive when on low speed)
5Wiper Motor Low Speed Output
6Wash Switch (positive for front wash)
9Seat Belt Warning Control Unit (4 or 29)
2Seat Belt Switch
3Door Switch
4Seatbelt Light
5"Key In" Power from Ignition Switch
6Main Fusebox Start/Run Power
7Automatic Shoulder Belt Controller
9Radio/Lights Buzzer (36)
1Main Fusebox Ground (not used)
2A1/4 (Left Parking Lights)
3Vehicle Speed Sensor
4Seatbelt Light (not used)
6Main Fusebox Start/Run Power (not used)
7A2/2 (Right Parking Lights)
10Fog Light Relay (110 for fog lights with low beam headlights only, 53 for parking light/high beam fog lights)
1Parking Light Power
2Headlight Switch Headlight Power (Low/High)
3Fog Light Switch Power, Fuse 10
5Main Fusebox Ground
6Low Beam Headlight Power
11Horn (53)
2To Horns
3Main Fusebox Ground
4From Horn Button
12Fuel Pump Relay (80, 67 or 167)
1Main Fusebox Starter Power (not used)
2Main Fusebox Start/Run Power
3To ECU (Fuel Pump )
4To Fuse 18, Fuel Pump, Oxygen Sensor Heater
5G2/6 (not used)
6Main Fusebox Battery Power From 30B
7G2/7, T1 (not used)
8Main Fusebox Ground (not used)
9M/4, U1/8, G2/5 (not used)
12Glow Plug Relay (102 or 104)
3Engine Temp Sender (preheat)
4Glow Plugs (Z1)To Fuse 18 (not used)
5G2/6 (not used)
9Water Separator, Glow Plug Light
remember to check out the website below for more help
http://www.xjamiex.com/mk2resource/electrical/CE2.html
Dec 30, 2014 | Cars & Trucks
My john deere l118 would not start only a clicking sound, so I replaced the battery but its still doing the same thing. any ideas?
use jumper cables and bypass the battery cables they do go bad check the safety switches as well
Apr 15, 2012 | John Deere Garden
Dc light stays on when power button off
When you turn the power button off, this turns off the motor, NOT the battery. There is a light switch, you can locate this in the owners manual. Turn this light switch off. If lights are still on then it will kill the battery. The power button does not turn off the BATTERY, just puts it in idle. This should be 100% the case if the light turns off when the battery is still connected. I would be glad to answer any more questions or details.
May 04, 2011 | X Treme X 500 Scooter
I power on my lenovo g55o, the power light come on, the battery charging light and the hard drive blinks for a couple seconds and goes off, but the monitor never lights up
You can try switching off computer, unplug the ac adapter, then the battery. When all power source are removed, hold the power button. Then put the battery back on then try switching the laptop back on.
Mar 12, 2011 | Computers & Internet
The laptop is not comin on
If it is now powerig on at all try to unplug it and remove the battery. After one minute plug everything back in and try turning t back on. Also check your power adapter and cable for tears or breaks.
Mar 06, 2011 | Computers & Internet
I have an L118...won't start unless I jump start it. On closer inspection, I found a disconnected wire...it's red in color and "hot". Have no idea what it goes to...could this be my problem as to why it...
Ok so where is it disconnected from? near battery, near ignition switch, near starter solonoid? How is it disconnected? unplugged? broken terminal? broken wire?
Jul 26, 2010 | John Deere Garden
Tablet won't switch on.
The power on switch is faulty. replace it. The battery is fine as there is green light meaning that it is supplying the current. And since the power switch is not lighting up it is faulty. If replaced, the tablet will function correctly.
Nov 16, 2009 | Wacom (PTZ930AC) Graphic Tablet
Battery died after experancing power door didn't close fully...
if you turn off the switch for the interior lights,an override,it will prevent the battery from going dead until you can get the door alignment or switch repaired.the interior lights,there is more than 5 will kill the battery for sure.
May 23, 2009 | 2003 Chevrolet Venture Passanger
ZD7000 Lights, no fans, power switch not working.............
Dismantled notebook thinking compressed air removed component or connection. Nothing. Reassembled most of notebook. Left battery and power disconnected for 6.5 hours, I later plugged only AC power into unit. Fans started spinning. Completed assemble of notebook and installed the battery. Blue lights returned. Problem seems to be the battery. Shorts out something and needs about 6 hours drain out. Works great now without battery, using AC power only. Ordered new battery.....
Feb 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Lucchese Classics L1188.64 Mens Full Quill Ostrich Boots Logo
66 people viewed this question
Top Lucchese Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Lucchese Wine and Spirit Expert? Answer questions, earn points and help others
