Nelsonic clock radio NLC 690
Need manual
Why does my nelsonic nlc690 am/fm alarm clock radio display 18:88 and not allow me to set the time?
Sounds like it is broken!
Unplug it and remove the backup battery if it has one. Count to 10 and put the battery back in and plug back in.
If that doesn't work, just buy another one as they are cheap enough!
Nelsonic Led AM FM alarm clock radio NLC690 AWESOME CONDITION
Jan 13, 2016 | Audio Players & Recorders
How to set presets on nelsonic clock radio nlc 618
To set this alarm first ensure that when you press the Mode button several times the FM/AM radio does not turn on . If the FM or AM radio does turn on or the lcd displays "AU" press the Power button that is next to the Mode button 1 time (pressing the Power button toggles you between 2 settings). You should now be able to press the Mode button at least 3 times without the FM/AM Radio turning on.
Next you press and hold the Alarm 1 or Alarm 2 button and (while continuing to hold down one of the Alarm buttons) press the Hour or Min buttons to set the time of whichever alarm button you are holding down.
When you have the alarm time set you can release the Alarm 1 or Alarm 2 button and press the same button (do not hold the button down this time) to cycle between the types of alarms you can use. You will see the blue circle indicator move between Buzz and Radio when pressing the buttons (Blue circle on left side is for Alarm 1 and blue circle on right side is for Alarm 2). There is a third option as well but I'm not sure what the alarms will do if you set them to it because the blue circle indicator disappears entirely after cycling to Buzz and then Radio.
Hope that helps!
Apr 23, 2014 | Audio Players & Recorders
I need help programming my tk-690 / tk 790 dual head dual band
Try this: join yahoo group Specific to your radio Make/Model, apart from great info you can download manuals, schematics and other goodies for your radio, all this is free.
Note: Re:- Downloads, only if available!!!
I hope this helps you with your query.
Cheers,
Peter
Mar 09, 2013 | Kenwood Kpg-44d 2.03 Radio Programming...
Broken cap on indicator for cleaning pond
call Sunterra LLC (LR Nelson) directly at (309)690-2460 (Ill #) or (800)800-0993 (Cal. #) They will ship you one right away !
Apr 12, 2009 | Sunterra 30016 Pond Bio - Filter 1000...
362 people viewed this question
 Grubhead
Grubhead
