Question about Olympus VN-4100PC Digital Voice Recorder
System call failed error message when plugged into computer
Error message 3807
Go to Kodak site. The error message means system failed. You will need to unplug the printer for at least 30 seconds and then plug back in. You also may need updated drivers.
Apr 13, 2014 | Kodak ESP 3250 All-in-One - Multifunction ...
New case fan running but still getting error message system fan failed.
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion a1720n PC Desktop
Received a error message "This software can only
This may sound stupid but make sure it is plugged in. Check the operating system and hardware requirements, if they don't meet the requirements, software will not recognize the device. Try different usb ports because sometimes computers have selective hearing and make sure your computer is initially recognizing the device when it is plugged in. If all else fails, don't try to install the software and head over to computer/my computer in the start menu. Right click and select properties. Click device manager in the hardware section or the bar to the left and look in the cd drive section. If you see your drive, right click and try any option about installing.
Mar 03, 2011 | LG Super Multi Blue Slim Portable Blu-Ray...
When i want to open a file it stops 3 times with error message, each time by pressing "ok" it continues to the next stage after pressing "ok" for the 3rd time it opens the file First Error message says"...
Error While Loading Plugin Html2pdf.api may be caused by windows system files damage.
Call on Adobe support number they will help you troubleshoot some common error messages related to Error While Loading Plugin Html2pdf.api that you may receive.
Adobe Customer Support Number
Jul 12, 2017 | Adobe Acrobat 6.0 Professional for PC
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
Jul 24, 2010 | Acer TravelMate 2480-2968 Notebook
Oxc18a0101 error message ink system failure
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone. http://www.fixya.com/support/t451942-help THIS WORKED!!! Don't throw it out try this first for: Ink system failed Error16x16_smiley-surprised.gifxc18a0101 on photosmart D7160. This is to reset the error code only,you will need to explain in more detail why you got the code and what you've done to correct it.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
MAC PRO dual2.3- freezes, gray screen crash, freeze with hi fan mode,kernel panic reports, all require start button shut down. Some forums suggest ATI card failure. I'm lost.
All computers will shut them selves off or crash when fans are failing, or have failed. Cooling fans are plugged into the motherboard, and firmware on the MB keeps track of the system fans, along with everything else. If a system fan is failing, or has failed, the signal is sent to shut down. Some PC's will shut down cleanly, others give error messages, and some just freeze up. Of course, Bad RAM, video cards, and hard drives with bad sectors, can also cause problems like you have discribed.
I would write down any error messages, and beep codes, and then look them up online for a place to start.
Oct 22, 2009 | Apple Power Mac G5 Desktop
I cannot install audio driver into my computer (DG31GL Board)
I am using a computer with DG31GL board, after installing vista, i reinstalled Windows Xp into my system after removing Vista from my system. Now my system is not taking the audio driver. I tried a lot. I am getting an error message that the installation failed. Please help me
Jun 08, 2009 | Computers & Internet
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
When I start my computer I get an error message: Disk I/O error.
The hard drive in that PC is failing or has failed. The drive controller is failing or failed. The drive controller on the motherboard is failing or failed.
Too many possiblilities but you should get the drive looked at first.
And I would suggest not truning that PC on anymore until you do so
Dec 09, 2008 | IBM NetVista A40 PC Desktop
Olympus VN-4100PC  Digital Voice Recorder Logo
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
