P1 code in wussi a/c
It start working fine, and suddenly it stops working and shows code p1. i have made the reset, and it's clean. what would it be?
4 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: I am getting [P1] code on my temperature indicator
Could you please re-post with the model number so I can look up the codes?
Posted on Feb 02, 2007
  • 3 Answers
SOURCE: P1 error code
Take out your filter and clean it, if its dirty your machine can frost up due to the lack of air flow and will not work correctly. Once you clean it, it should be fine.
Posted on Apr 06, 2010
  • 94 Answers
SOURCE: My tankless water heater Rheem, suddenly stopped working. I do not smell any gas, & remote control shows P1, What I should do ? Thank you.
P1 according to the manual states you are not getting enough water going in to operate the unit. I would clean any filters that lead to your water heater, just make sure you turn off the electricity to the unit at the breaker box. For a list of the codes and what they mean go to the website www.hometips.me/Tls/Rheem. Also the toll free number to Rheem's national service dept is 800-432-8373. Hope this helps.
Posted on Dec 03, 2014
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Wussi ...code EO
My airconditioner Wussi is giving me code E1. What should the technic do for this code
Dec 31, 2013 | Heating & Cooling
Wussi A/C inverter show code P4
Como encontrar el code del A/C Wussi modelo 18 (41O)
Nov 23, 2013 | Heating & Cooling
Error code f1 e3
Try this out,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
Nov 27, 2012 | Kitchen Ranges
I am geting a P1 error code
P1 error code is not enough water flow to operate the unit: increase water flow to unit.
http://waterheatertimer.org/pdf/Rheem-Error-code-P1.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start-point for troubleshooting.
Page 18 of maintenance manual shows how to clean water filter monthly.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Other causes can include faulty sensor, clogged in-line filter, clogged water softener, sediment in pipe, sediment at elbow, bad check valve, water leak, etc.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Rheem Tankless Hot Water Heater...
Code on Top
I have another of their dehumidifiers, the MDF1-30AE. The first time the P1 came on, the unit stopped, because the filter needed cleaning. Recently P1 came on but the unit didn't turn off, and I had already cleaned the filter, so I phoned Midea customer service at 1-866-646-4332. The man told me P1 means it's in defrost mode and said to just leave it on and the P1 will eventually go away. It's been a while though....
Dec 01, 2009 | Midea MDC-45AE Dehumidifier
P1 error code
Sep 13, 2008 | Danby DDR2506 Dehumidifier
P1 and P2 error codes
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
May 25, 2008 | Danby DDR2506 Dehumidifier
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
