Question about Sony Audio Players & Recorders
I replace the belts and must of dislodged something. the electrics are fine, the motor turns, but the tape doesn't advance. i suspect that some gears are engaging
  • Sony Master
  • 1,258 Answers
You do not give a clue as to what model this is. However in some Sony decks of the cam assisted by Flywheel designs the new belt is not all that it needs. It needs a tear down of the transport to get rid of hard or dried up grease. Most of the time it is not worth the deck to have it done. I worked at Sony at one time. A lot of years have gone by since then.
Posted on May 07, 2014
2 Suggested Answers
SOURCE: Onkyo TA-2700 - Won't Play Tapes
Call Onkyo service/parts department for part number(s) and ordering instructions
Posted on Aug 15, 2008
Maytag Neptune Drying Center MCE8000AYQ Why does it not tumble?
I would start at a belt. Most cities have a do it your self appliance store, they can order you the part and ship it to your door or you can pick it up. Some Belts are as low as $16. Before condemning it is worth the gamble. Before Disassembing the unit go to U tube search out your dryer there should be an instructional video on how to replace it. Also pay attention to how the current belt is fed. I take a picture with my phone or diagram it. It helps especially if you get called away from the project. Hope this helps
Jun 21, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Drum wont turn but the moter does
Hello Deanna - This particular issue could be caused by a variety of reasons. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer is not agitating in whites and slowly in colors. What and how do we troubleshoot?
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
Aug 05, 2012 | Frigidaire FEX831CS Top Load Stacked...
Delta 1313314 motor runs but blade doesn't turn
With this perticular motor I would suspect that the issue is a broken drive belt. The belt is located on the back side of the motor, behind the plastic end cap. The belt is a 10" long cogged belt and looks like a timing belt.
Jan 20, 2012 | Delta Saws
Tape will not turn
The more detailed the description of the problem, the better for diagnosing the root cause. Thanks.
It sounds like you have a couple of problems. I'll address them as you have them numbered above.
1. Decks typically have belts to drive the various 'reel' mechanisms. Therefore, they can slip without breaking anything inside the machine or the tape. Your first symptom leads me in that direction.
2. That it migrated is mysterious, unless Sony is using a common motor to handle both decks' reel duties.
3. This symptom may have something to do with the root cause of both sides jamming...
Do the cassette well doors come off, say, for cleaning? Could they be dislodge? If so, they may have something to do with the jamming problems in # 1 and #2 as the doors play a part in positioning the cassette and holding it in place against the reel motor cogs. How do the doors operate with NO tape inserted?
Does it take excessive force to close the door only WITH a tape? make sure the tape is fully seated before closing the door. The capstans (directly below each reel cog) have to engage through the small holes at the lower edge of the cassette. They should be straight and clean. Any dirt or oxide on them will cause problems as these are what move the tape at the precise speed necessary for good playback or recording.
My hipshot recommendation, otherwise, is to look around inside the cassette wells very carefully for any foreign matter, debris, dust bunnies.
Do you maintain the deck as recommended?
Apr 02, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Dryer doesent turn, belt seems fine
belt is what turnd the drum so, is the machine running at all??? if the motor is running and the drum ois not turning then i would suspect that teh belt has dislodged off the tension pulley down by motor
Mar 14, 2009 | Kenmore Dryers
In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Jan 18, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Drum doesnt turn... motor fine.
From your description I would suspect a broken belt although I am unfamiliar with your model. Once the belt [which transfers drive from the motor to the drum] breaks, it would'nt matter how well the motor runs, it can't turn the drum.
Hope this helps!
Oct 08, 2008 | Bosch Axxis WTA 4107 Electric Dryer
Noise
What does this noise sound like? If it's a squealing noise, chances are that it is a belt going bad. You can purchase a new belt at your local Sears, or probably even your local grocery/department store. The vacuum belt is easy to replace and inexpensive. Instructions for belt replacement are in the owner's manual, or sometime on the belt's package. Hope this helps... Please take a few seconds to rate how helpful this suggestion was. Thanks and good luck!
Aug 24, 2008 | Kenmore Progressive Bagless Upright with...
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
