Question about Aroma ARC-838TC 20-Cup Rice Cooker
Will not get hot
Only gets warm, does not get hot enough to cook
I'm not sure if it's the thermostat that is not working but the oven only just warmed up and didn't get hot enough to cook food
Probably a thermostat going bad shutting elements off. But make sure the element doesn't have a burnt wire or the plug isn't burnt which will cause insufficient voltage
May 05, 2016 | Ovens
The grill element gets warm but not hot enough to cook. I think this means the element itself is ok but something else isn't. Any suggestions?
could be a faulty thermostat or a problem switch for the grill
call in a technician for a proper diagnosis
Apr 30, 2016 | Ovens
HOW DO I OPERATE IT, EG HOW TO USE IT TO WARM ALREADY COOKED FOOD AND PASTRIES
I usually just put the food in a microwave proof bowl and put it it and push the button number that I think will be hot enough but not so hot it will burn my mouth .1 or 2 minutes is more than enough for most 30 to 50 seconds for coffee and 10 to 15 seconds for pastry
Sep 03, 2015 | Microwave Ovens
The main oven gets warm but nowhere near hot enough to cook anything. Could it be the element? And if I replace it myself, what is the pen like object attached to a wire at the rear of the oven? Many...
if it gets hot but not hot enough its proberly your thermostat and the pen like thing over the wire is just a cover to insolate the bear spade connection
Aug 11, 2011 | Zanussi ZHQ575 Electric Double Oven
Pilot light stays lit but oven will not stay lit
I would be interested to know just how long it is that the oven does stay lit. All ovens, gas and electric, cycle off and on throughout a baking cycle, to maintain the proper temp. If the flames or the power to the element were to stay on at full power for the life of the food's required time in the oven it would most likely wind up charred. The temp would simply continue to rise, up and up and up. If that's what it appears to be doing, then it's just working normally. If it goes out completely and stays off, doesn't come back on in a few minutes, then it may be in a keep warm mode. Many ranges have a TIMED BAKE cycle available, so you can set the clock to start the oven at such and such a time, cook the food and then shut off. Once it's finished with the cooking cycle, it goes into a keep warm mode, where it will come on for a short time and then go off, to maintain about 180 degrees. Not hot enough to really cook anything anymore, but hot enough to keep it warm for you when you get ready to eat.
If this seems to be the way it's acting, then look for the timed bake function on the console and set things back to a manual mode.
Apr 22, 2011 | Kitchen Ranges
Which will provide the lowest heat? low 10 hours or warm setting. Thanks
The WARM setting is the lowest heat. Here's a quote from the user manual:
"WARM is ONLY for keeping already cooked food at the perfect serving temperature. DO NOT cook on the WARM setting."
This is because at the WARM setting, the temperature doesn't get hot enough to kill food-borne bacteria.
Jan 18, 2011 | Rival 38601 Smart Pot 6-Quart
Breaker flipped on my oven while cooking a turkey
If the oven was still slightly warm to the touch when you came home is probably fine. 45 minutes was not enough time to get the turkey hot down near the bone, so if it was cool I would discard it. But if you were lucky and it was still warm, go ahead.
Sirwriter - (Smoke and barbecue tons of chickens and capons)
May 16, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Ge gas oven with electronic ignition
yea sounds like you have a bad oven ignitor, tell tale signs are not heating past warm, smells gas, too long to cook, popping noises while cooking. Id replace that ignitor. Although it might appear to "glow" not glowing strong enough
Feb 28, 2008 | Kitchen Ranges
Not hot toaster
you have to ask the guy you got it from if they have a spare part for it dont forget to bring it with you
Nov 04, 2007 | Oster 6297 Toaster Oven with Convection...
Gas oven won't heat
You most likely have a defective oven bake ignitor.  Call an experienced tecnician.
Oct 09, 2007 | Ovens
Aroma ARC-838TC 20-Cup Rice Cooker Logo
27 people viewed this question
Top Aroma Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Aroma Kitchen Appliances - Other Expert? Answer questions, earn points and help others
