Question about Pyle Rack Mount 2000w Amplifier pt710
Stero hook up - Pyle Rack Mount 2000w Amplifier pt710
The color of the wire is red. Instead of getting a harness can I just connect it to a red wire under the dash. But there is two red wires under it
no you cant just hook it to a red wire because its red. what are you hooking up? im assumeing a stero, you can however hook up it without a "harness" but you need to know what you are hooking up. since its red its most likely a power wire on your stero but not always the case on the vehicle. also some wires are switched power or "remote" power meaning when the key is turned off they are not electricfied or "hot" and some are constant meaning they ar always hot. give more details and i can help more.
Oct 31, 2014 | Car Audio & Video
Cant get my phone mp3 to play through my stero
When you hook up the phone to your stereo did you put your phone in mass storage mode? It has to be turned in to storage mode in order for the phone to connect to the stereo. Try it and get back to me....
Nov 09, 2011 | Pioneer Car Audio & Video
I'm connecting my tv to a stereo receiver to get stero sound through the stereo speakers.done this a hundred times with other tv's but can't get this one to work.
how do i hook up my stero to my dynex tv? stero has no hdmi cabl neither does my cd player. i also go through my cable box not high def Thank u for any help
Jan 02, 2011 | Dynex DX-L32-10A 32" LCD HDTV
2005 Subaru Impreza STi Matsushita stero deck
Nope, yer sol. Check out this link: http://forums.nasioc.com/forums/showthread.php?t=749402
Jan 25, 2010 | Panasonic Car Audio & Video
How to hook up a subwoofer to my computer?
i to have that sub and i hook it up to my dell 1501 i use a mini steroe plug it has two input so you can hook up two device get two y cables on one end it will have a plug like your headphone plug on the other end has two male the ones you hook up at the back of your steroe the other cable is a y cable as well this one has two female end and steroe end to hook up to the sub connect both wires to become one male to female one end goes to the computer the other end the sub you cant do it wrong there is only one plug that will fit hope this helps .
Jan 12, 2009 | Jensen JW250 Main / Stereo Speaker
ELECTRICAL PROBLEM
The prob seems like you have connected the power to your stero from the wrong place. You cut into live a wire for the power, this should be connected at the ACC on your fuse panel. Also make sure you stero has a good ground! Frankster016
Oct 23, 2008 | 1989 Ford F 150
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
Pyle Rack Mount 2000w Amplifier pt710 Logo
280 people viewed this question
Top Pyle Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Tom Chichester
joel maureal
Are you a Pyle Computer and Internet Expert? Answer questions, earn points and help others
