Question about Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive
What is the DC power spec - Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive
I have Cintre desktop speakers but no power supply. Where can I get one?
first off need to know specs what voltage it uses ac or dc
amp draw and volts should be market on speakers then you need to no if dc volts what part is negative and positive on terminal connection send model #
Feb 27, 2015 | Audio Players & Recorders
What is the AC DC adapter spec for SEAGATE 9NK2AE-500. i lost the original adapter that came with this external seagate freeagent harddrive.
most of these external hard drive units work with a 12V 3 amp DC power supply like this one
OEM AC POWER SUPPLY SEAGATE 9NK2AE 500 Free Agent HDD
Make sure you get the correct power connector for your country.
Aug 17, 2014 | Computers & Internet
No power ac or dc IFR 1200 super s
Try another Cord/charger, with the EXACT same power specs, without the battery installed. If it works on the AC/DC cord/charger, replace the battery with a genuine battery with the exact same power specs.
Mar 15, 2013 | Computers & Internet
My dell inspiron mini notebook wont turn on
Is it getting power? Check the plug at the computer for DC volts? Has the AC/DC jack in the laptop been damaged due to pulling on the cord? Try another cord/charger with the EXACT same power specs.
Mar 08, 2013 | Dell Inspiron Mini 10 Notebook
I have a Midland Public alert weather radio Model # WR-300 Problem is lost the DC in power pack. Wondering what the DC input voltage and current are for this model. I have some power packs but want the...
It takes 4 AA batteries, that is 6 volts. You will find that a 6V 500Ma power supply will be the right thing, just make sure that the polarity of the plug is right!
Feb 11, 2011 | Vacuums
I have an old SPX90 Digial Reverb with a dead powersupply. The part number on the board is VA81400. Is this part number correct? Is the part still available? We tried ordering it from the Yahama dealer,...
Any power supply will do as long as it has the same specs as the dead one, which will be:
Input : x Volts AC
Output: x Volts AC or DC
Watts: x
Amps: in millamps
Polarity: (for power supply with DC output only) Center pin = plus or Center pin = minus
You should be able to find the matching transformer/adapter/power supply at Radio Shack.
More info, let me know.
Charlie
P.S. The power supply you received may be the correct one -- check to see if the specs match the old one.
Aug 29, 2009 | Audio Players & Recorders
Cobra HH 40 charger specs
I have a Cobra HH-40 CB radio and am charging it as I type. The included charger is rated at 16V DC, 100mA. The pattery pack charges 10 AA rechargable batteries (the manual specifies NiCd, but you can also safely use NiHM). The 12V DC car charger included cannot be used to charge the battery pack, but can power the radio.
Mar 25, 2009 | Cobra Radio Communications
Adapter specs
hi..
i've also got one without DC adapter... and looking around. find this link here: http://www.corg.ru/products/Network%20equipment/Compex/TP1008C saying: Power Supply: External power adaptor input 220V-110V, output 7.5v/1A
hope it helps
Aug 07, 2008 | Compex MicroHub 8 Networking Hub
Acomdata PHD060U2E-54 60 GB USB 2.0 Hard Drive Logo
19 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
