Question about Yamaha DVX-C300 System
Speaker Error How do I get my system to work when all I get is Speaker error when I turn it on?
2 Suggested Answers
SOURCE: Speaker error
Try checking the volume on your subwoofer i had the same problem. I unplugged the system and had the same error message pop up. So i checked the volume on the subwoofer, and it was set to max, i set it to normal and i haven't had any problems since
There are 2 ways to check your volume
1...On the remote there is a button labeled "BASS" press it, and on the display it will tell you a number between -3 and +3, If no number appears then it should say either "MIN" or "MAX" if it's at max use the volume control on the remote to turn it down to "0"
2...On the remote press "SET UP"
.....Select the Volume icon by using the arrow keys, press "ok" or "enter" to access that icon
.....Select "Speaker Setup" using the arrow keys and enter button
.....Select Speaker Volume by pressing enter
.....scroll down to "SUBWOOFER" and make sure the volume is no higher than +4dB
....Once done press "SET UP" on the remote to exit the setup screen
*Note* - The speaker volume option can only be chosen when nothing is playing on the player, or the disc tray is empty, You also have to be in either, Ipod mode or DVD mode to access this menu.
Hope this solves your problem, and i apologize on the delay of this solution ^_^
Posted on Aug 27, 2009
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
Stereo system connected to computer audio is not working and it was working before
Recheck your settings. Go the lower right and see if the speaker settings are correct. Vol. and speaker connections! You may have turned off the speaker off by error. If the settings are OK, try a headset with right/left ear buds and if you get sound, then the speakers are a problem.
Dec 31, 2013 | Computers & Internet
When playing DVD, it's sometimes display 'PROTECT' and stop playing.
Check if you receive the error when playing any DVD in particular.
What happens when you take out the DVD and try playing it again? Does it play
This protector error denotes several possible problems. Heat, volume level and incorrect DVD settings may be the cause of the problem. The following steps will help you correct your problem and rid your amp of its "Protector" error.
  • Examine your volume setting to be certain that your volume knob is not at maximum. Having your volume cranked too high can cause the capacitors to overheat, shutting down the receiver.
  • Unplug your receiver and disconnect your speakers from the terminals on the back. This will allow you to determine if the error is internal. Plug your receiver back in and look for the same error message. If you continue to get the protector error without having your speakers connected, you may have an internal electrical problem. In this case, contact Sony about finding a repair center.
  • Reconnect your speakers one at a time. The order of connection doesn't matter. When reconnecting, be sure that you do not have your positive and negative speaker wires crossed in any way. After each connection, test your amp by running it with a source. Give each speaker a few minutes of power before connecting the next one. This will help you isolate which speaker terminal is causing the error. When the protector error returns, take note of which speaker connection caused it. Check this speaker wire for shorts or torn shielding.
  • Examine your ohm rating of your speakers if you have no shorts or wiring issues. Sony receivers are not compatible with speakers lower than 4 ohms. Connecting a lower ohm-rated speaker will cause an error.
  • Turn off the surround sound option if you have both your A and B position speakers in use.
  • Keep your receiver well ventilated. Overheating due to poor ventilation can also cause Protector errors.
  • Examine the sampling frequency of your connected DVD player. If the error only occurs when you watch a DVD, the sampling frequency of the DVD player may be set too high. Check the sampling rating in your receiver's manual and in the DVD player
Mar 22, 2011 | Sony DAV-S500 System
Receiver shuts off says check sp cable
The reciever is telling you that their is a problem with the speaker cable. I sugges pinpointing which speaker cable it is by turning the system off then unplug all the speaker cables and then plug one in at a time, waiting inbetween allowing enough time for the system to pick up the bad sp cable. Then once you find the correct cable check it from the reciever to the speaker for any signs of breakage, shorts, or damage. Check the speaker connections from wire to speaker and from the wire to the reciever. If all that fails then check the speaker itself, try swaping another one in the position to see if the problem is solved. Hope this works.
Mar 06, 2011 | Yamaha RX-V2700 Receiver
Shuts off when turning volume up. Error message
go to a computer store and tell them to rebot your computer that what i did it worked for me it should probly work for u
Dec 18, 2009 | Yamaha HTR-5760 Receiver
The DVD an CD doesn't work
Check speaker connections and wires and make sure all wires are plugged properly. If problem still exist then unplug speaker one=by-one and test home theater to determine what speaker is causing Protect error.
May 17, 2009 | Sony DAV-C700 System
ERROR 12 - but all the speakers work. why?
The manual lists no error code 12. Check that all speakers are in the correct place in the room and that they are not out of phase (that on each speaker positive is connected to positive on the receiver and negative is to negative). Make sure that the mic is laying flat, and that the room is quiet. If using a sub woofer switch the speakers to small.
Jan 29, 2009 | Sony STR-DG500 System
Speaker Detect error Left Rear
Hey there.
I had the same problem until i figured out that if u dont have surround speakers connected it will be a error when trying to configure the rear surround speakers.
So if u are running a 5.1 system and have hooked up ur surround speakers to the back surround speaker port u have to change them to the surround speaker port.
Hope this work for u
Jan 11, 2009 | Audio Players & Recorders
Speaker error
Oct 25, 2008 | Yamaha DVX-C310SL System
Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
May 30, 2008 | Panasonic SC-AK600 CD Shelf System
Yamaha DVX-C300 System Logo
18 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
