Question about Yard Machines 121R 31cc 2-Cycle Gas Powered Cultivator/Tiller
Need chock on won't accerate - Yard Machines 121R 31cc 2-Cycle Gas Powered Cultivator/Tiller
My accer desk top won't boot up and an alarm is sounding
Alarm? Beep? Pull the AC plug, plug in , try again. Reseat the Memory Mods, replace CMOS battery. Need more info to give a informed solution. You didn'y supply your Model of Acer or OS? Take a look at Acer Support: http://support.acer.com/us/en/default.aspx
Dec 26, 2012 | Computers & Internet
I have a 2000 excursion and sometimes wen I accelerate it starts chocking out at 2000 rpm and won't go any higher
Mostly your MAF MASS AIR FLOW SENSOR needs cleaning.
1st Disconnect the battery ground cable
then open the engine air cleaner.
  • Disconnect the MAF sensor electrical connector.
  • Release the air cleaner clamp.
  • Separate the inlet side from the outlet side of the air cleaner.
  • Remove the MAF assembly.
  • Remove the nuts and separate the MAF sensor from the MAF sensor plate.
As shown
then follow the steps in the video.
HOW TO CLEAN A MASS AIR FLOW SENSOR
if that did not clear your engine chocking then make sure there is no Vacume leak.
hope that helps
May 01, 2012 | 2000 Ford Excursion
Accer aspire 5920 laptop no power
try to remove cables and battery , then press and hold the power button for 8 secs. Reinsert the cables and battery back, then turn it on. If no power, then that propels you to contact Acer for repair because power supply won't work on your laptop..
Jun 16, 2011 | Acer Aspire 5920-6727 Notebook
Reformet accer laptowindow corapetp Ihave NO cd Iweant purchase
Press "R" to go to the "Recovery Console while you boot the Windows".
Dec 24, 2009 | Acer Aspire 5610-4648 Notebook
I have a 125 thumpster it will satart with the chock on and will run with the chock on if i turn the chock of it will die if i try to ride with the chock on it will back fire what do i do
That is a sign of carb problems! You will need to remove it and disasembel it and clean every nook and cranny. Use carb cleaner and a air compresser.
Dec 20, 2009 | 2002 Yamaha TT-R 125
Won,t start When I used it last it lost power and i had to run with the chock out.Than it quit,and would not start again
The carburetor sounds like it needs a rebuild kit. I would have a technician do a compression test on the engine. It needs to be at least 100 psi to run. Anything lower than that you are looking at an engine rebuild.
Good Day.
Oct 30, 2009 | Homelite 'Yard Broom' Leaf Blower
Have an italian laptop need to change to english
while installing the operating system..it will ask for ur language preference....select english in dat and it will b in english...
Jun 10, 2009 | Acer Aspire 6930-6455 Notebook PC
Accer laptop
This button is to asign any application to be opened directly on pressing e button. Need windows vista to work on it.
Jun 09, 2009 | Acer Aspire 5315 Notebook
Jeep won;t start..new fuel pump installed
try the fuel filter and make sure you have proper oil pressure!! Remeber if you have tried craking to many bad times then the plugs are going to be fouled out!! Means that they are going to be drowned with gas and need replacing!! Also make sure your fuel pump is coming on!! You should hear a hissin or a hummin noise back from the fuel tank!
Dec 07, 2008 | 1994 Jeep Grand Cherokee
Yard Machines 121R 31cc 2-Cycle Gas Powered Cultivator/Tiller Logo
26 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
