Question about Panasonic DVD-S35 DVD Player
First let me preface my problem with the fact that Im 73...recentlty moved and the up down button is missing and also remote
Missing up down button and remote
Any Idea how to bypass/reset immobiliser as remote is broken? Any button located inside? 1991 Toyota Camry
stock or not
what country,?
we can not guess these missing facts.so.....
our cars have no such thing ! in USA, 1991. non.
Jan 30, 2015 | 1991 Toyota Camry
I am trying to get my Dish Network to work on my Phillips HDTV. Dish Network told me that my television needs to be on channel 73 and when I try to put that channel in with the remote, the channel...
on your tv go to menu & somewhere there it will say scan for channels so it will scan for about 5 mins then grab your remote & turn to channel 73 & there you go . if not try moving the tv to a different source like AV or YDRB
Jun 23, 2011 | Cell Phones
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I am trying to set up dish network on this tv i can not get the channel to change to 73 only 70 and 76 i have no remote control for this tv just using whats on the tv
Hello. If this has not yet been resolved, I have some simple steps for you that will help you out.
First off, it sounds like the remote needs to be programmed, and since I do not know the particular DISH remote you have, here are the steps for a power scan, which will scan the TV for the correct code.
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Then once you are on 73, that picture will work. You can also try the alternate channels, which are 22 and 21. That may also give you a picture. I hope this helps!
Becki Barned
DISH Network Customer Service
Feb 04, 2011 | Toshiba 27A34 27" TV
I need to get my TV on channel 73 and i can't figure out how to do that
To get the tv on channel 73 you will need to use your remote that came with the tv. Type in channel 73 then hit ok or select. Or you can change the chanel buy using the channel button on the Tv.
Dec 26, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Mtisubishi TV (CRT), Model CS-2610R
that is because you do not have the correct input connected or the set needs to have a channel program redone
May 16, 2010 | Televison & Video
Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Oct 22, 2008 | Sony DAVHDX265 System
Remote Control Control Codes
has anyone solved this problem???
Jan 13, 2008 | Audio Players & Recorders
Toshiba 36a41 television
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
Jan 21, 2007 | Sony KV-36XBR250 TV
Panasonic DVD-S35 DVD Player Logo
16 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
