Question about Fujitsu Heating & Cooling
Front grill ice build up
  • 25 Answers
Check the air filter and if it is dirty, replace..
Turn equipment off and let the ice melt.
After ice melts, place a/c in cooling mode and set the thermostat to 3 degrees below room temp display.
The indoor unit fan should start blowing cold air immediately and then turn off once the room temp drops one degree below the cooling temp setting.
If the indoor unit does cycle off, check the outdoor unit and make sure it turns off at the same time.
If the outdoor unit continues to run and the indoor fan is not running, the indoor unit will ice up.
A defective compressor relay that is stuck in a closed position will cause icing of the indoor unit because it keeps the compressor running when it should turn off with the indoor fan.
Do you have an error code being displayed on the controller?
Is there an led light that is flashing on the indoor unit?
Another possibility causing the indoor unit to ice up is if the freon in the system starts to get low.
Make sure the ice has all melted for this next check.
Pretty easy to check without special tools.
If the air filter is clean and there is no dust/ dirt blocking the fins on the indoor unit, turn a/c back on to cool and check that the indoor unit fan comes on and is blowing air good.
Once everything seems to running good go to the outdoor unit.
There will be two lines with black rubber insulation covering them.
Peel back the insulation three inches on each line and observe the copper lines.
If either line starts to frost up the a/c system is most likely low on refrigerant.
Another cause of indoor unit icing could be that the aluminum fins behind the air filter are clogged with dust or other foreign material.
This would block the air that must be pulled in causing the indoor unit coil to become too cold due to lack of air flow and it will ice up.
Operating the cooling system when the outdoor temperature is below 60 degrees can cause the indoor unit to ice up also.
I'm Robert.
Florida certified a/c contractor. 30 years experience.
Hope this helps.
Posted on Mar 21, 2014
Samsung side by side fride
The first thing I would check is that the condenser grill under your unit is clean and the air flow is not blocked (also that the lower fan is blowing air across the coils. Even if that is not the total cause it will help your unit operate more effeciently. The condenser grill is under your unit accessed by taking off the front kick panel and also through the rear.
The second thing I would check is for ice build up around the evaporator coil (located in the back of the freezer section). If there is ice build up then you probably have a defrost system failure. This circuit is made up of the defrost heater, defrost thermostat (both located in the freezer section close to the evaporator coil) and the defrost timer which is located in the fresh food side (or if newer frig, part of the control board)
Jan 06, 2012 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS 264A side by side fridge not cooling or freezing
The first thing I would check is to make sure your condenser grill is clear of dirt and lint balls. If it is extremely dirty the grill can't disapate the heat from the compressor. The best way to clean, that I have found is with a shop vac and an air compressor. Blow from the back and vacuum from the front. This will require the removal of the rear shield and the front kick plate. MAKE SURE YOU UNPLUG THE UNIT FIRST!
The next thing to check is the defrost system. If that has failed you will have ice build up on the evaperator coils behind the shield in the freezer section. You can manually defrost your unit by unplugging and then use a hair dryer to remove the ice. But be ready to deal with the water from the ice! If you do have an ice buildup, then you can check the heating element and the thermostat that are located close to the coils in the freezer section - and can be checked with an ohm meter. Or it could be the main board since the defrost timer is built into it.
Dec 15, 2011 | Refrigerators
Refrigerator and freezer is too warm on a GE side-by-side model GSS23WGTJBB
The next thing to check is the defrost system. If that has failed you will have ice build up on the evaperator coils behind the shield in the freezer section. You can manually defrost your unit by unplugging and then use a hair dryer to remove the ice. But be ready to deal with the water from the ice! If you do have an ice buildup, then you can check the heating element P/N WR51X10101 and the thermostat P/N WR50X10065 that are located close to the coils in the freezer section - and can be checked with an ohm meter. Or it could be the main board since the defrost timer is built into it.
Dec 15, 2011 | GE Refrigerators
Fridge not cooling properly
Ice is melting in 14 year old amana refrigerator. Should I look into replacing or calling a repairman?
I would see if the old girl still has a chance at life before replacing it. First, make sure that the condenser grill (under your refrigerator) is not extremely dirty and that the fan is operating. Make sure that you have good air flow from front to back. You would be surprised how much lint, dog hair and lint will accumulate on the inside of the back panel. Clean it out!
If that isn't the case then I would check for ice build up behind the inner panel of the freezer compartment. If there is, then your defrost system is not working and you will need to figure out which component needs to be replaced (defrost heater, defrost thermostat or the defrost timer).
If you do have ice build up then you can defrost the system by unplugging the unit and using a hair dryer to melt the ice, but be ready for the amount of water!
I have a old Amana that I bought in 1983 and it is still working great! They have excellent components that stand the test of time.
Jul 28, 2011 | Amana Refrigerators
I have a maytag plus side by side refridg.. About two weeks ago the freezer started warming up and now is not any colder than the refridgerator side. Also the refridgerator side is now warming up. It...
Airflow around the condenser grill is very important. So you should take off the front grill and vacuum out that area the best you can.
Since this is a gradual warming trend you might have ice build up on your evaporator coils (usually means that defrost circuit malfuntioning). If you remove the food, shelves and back panel of your freezer section, you will be able to see if there is ice build up. If there is, unplug the unit and then use a hair dryer to melt the ice. Make sure you are ready to deal with the ice melt with either spongs and bucket or a wet/dry vac.
Jul 14, 2011 | Maytag Refrigerators
Ge profile side by side refrigerator is not cooling to the recommended temperature
The GE profile has a smaller condensor grill, so keeping the area free of debri and dirt is very important. Check the grill and vacuum it off, also make sure that the back is kept clear of items since it needs front to back air flow. If that doesn't help the cooling then I would check for ice build up in the freezer (behind rear inner panel) that could be giving the thermostat the wrong readings.
Jun 07, 2011 | Refrigerators
How to take the front grill off?
the grill should just snap off with a pull, evenly from both sides. If coils can be accessed from the front, there are no more coils in the back. The screwed on cardboard in the back is covering a fan so it can pull air directly over the compressor and evaporate the water in the drain pan. You should periodically check to see if water is draining into the pan, if not, the evaporator may be getting heavy ice build up, therefor not cooling 100%
Jul 15, 2010 | Amana 25" Cu Ft French Doors Bottom...
Freezer cold. Refrigerator very warmer.
Hi there. This should be a self defrosting unit. Check the defrost clock. It's usually behind the grill at bottom front of frig. or near the compressor. There is probably a little window on the clock motor where you can see it turn. You can manually advance the clock to put the unit into defrost mode. Check the defrost heating element. This is the usual problem. It is under shrouds where all the frost builds up. If element good, check defrost thermostat connected to element mechanically and in series electrically.
Thanks
Paul
Jul 12, 2009 | Kenmore 61042 Top Freezer Refrigerator
GE SIDE BY SIDE/MODEL #GSS25JMDCC
I also had a loud fan and it was caused by ice build-up on the fan in the back of the freezer. From inside the freezer, I removed the plastic grill that covers the fan (I think I also had to remove the side rails and ice maker) then just let the fan defrost in the sink. Made sure it was nice and dry before putting it back in or else ice would just form again. I also took a sheet of plastic and put it between the ice maker and fan grill to stop water from dripping onto the fan and haven't had a noisy fan since. I just need to remove the ice build-up from on top of the plastic sheet every now and then, but that's much easy than taking everything apart to get to the fan.
Feb 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Heating & Cooling Logo
207 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
