Question about Kocaso M752 Black WiFi 7" Android Tablet PC w/ 4GB Storage & 512MB RAM
Trying to download the fix - Kocaso M752 Black WiFi 7" Android Tablet PC w/ 4GB Storage & 512MB RAM
  • stephen Adams Feb 22, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? To fix what?
Fb not working on my iPad Help
you could try uninstalling it and downloading again .
Nov 28, 2015 | Tablets & eReaders
Can't download anything
Have you data on the tablet and is it enabled.
Mar 13, 2015 | Tablets & eReaders
My ideapad says the process com.google.process.gapps has stopped. How do I fix this?
1. Go to MENU
2. Go to SETTINGS
3. Go to APPS
4. Look for DOWNLOAD MANAGER under ALL
5. Disable it then enable it
Menu-> Settings-> Apps-> All-> Download Manager (Disable then enable)
Or you can try: settings ----> application manager ----> all ----> click the bottom left touch button and select reset apps (this will not erase the apps) this will only restore the apps into its fixed state
Mar 07, 2015 | Tablets & eReaders
How do i fix the problem
You may have corrupted system files. Factory reset merely re install some of the system files but not the entire OS. It is better to reflash your ROM though the problem may be resolved by reinstalling Google Services Framework.
Jan 11, 2015 | Tablets & eReaders
What can i do to fix my 7inch polaroid tab after downloading android armour nd battery booster it shut off and turns back on but while trying to load it shuts off again?
Might be your tablet not supported to that app or possibly it should not be a appropriate application :
So download this app from play store
Battery Doctor(Battery Saver)
and if this fails
possibly problem in you tablet software go to replace it .....
May 14, 2014 | Polaroid Tablet Computer PMID701
I have a proscan PLT7223g tablet and trying to download app from goolge play store and I'm getting error code 911 What is this and how do I fix it
You can avoid these errors if you have a stable internet connection. If the internet disconnects in the middle of the download then the error might occur. You can also try going to settings, applications and locate the google play store and tap it . On the play store tap clear cache. One of the reasons that the error occurs is if the download manager was moved to the sd card. Make sure also to check that. You can unmount the SD card and try.
Jan 16, 2014 | Tablets & eReaders
Audiosonic km7j2 tablet
Do u haveproblems with downloading apps?? Mine logs on but everytime i try and downloAd apps it says i need the google play store app..... i cant figure out how to download it.......
Aug 26, 2012 | Tablets & eReaders
HELP MY APPSLIB NOT RESPONDING
I talked to Coby USA about this concern today. They are aware of the issue and are working on a fix. They said so many were sold for xmas that the appslib server crashed because so many people were trying to download apps. This started on Dec 25th, but worked fine up to that date. They said it could be a couple of days before it is fixed and to keep trying the appslib. There isnt a problem with the tablet................
Dec 30, 2010 | Coby Kyros 716829701508 Tablet PC
Kocaso M752 Black WiFi 7" Android Tablet PC w/ 4GB Storage & 512MB RAM Logo
21 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
