Question about LG LFX25978ST 33 " Wide Ultra Capacity 25cu.ft 3 Door French Door Stainless Steel Refrigerator - LFX25978ST
Reset for lg side by side refridgerator - LG LFX25978ST 33 " Wide Ultra Capacity 25cu.ft 3 Door French Door Stainless Steel Refrigerator - LFX25978ST
Error code listing for LG lsc27931st Refridgerator.
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
http://www.searspartsdirect.com/refrigerator-repair/error-codes/lg-bottom-freezer-refrigerator-error-codes.html
May 18, 2015 | LG LSC26905TT Side by Side Refrigerator
Why does the rubber sealer on refridgerator door and freezer door get hot
Inside the frame is a warm bit of pipework, or sometimes a mullion heater, that stops the seal freezing to the frame.
Aug 21, 2014 | LG LSC26905TT Side by Side Refrigerator
Freezer works fine. Refridgerator wont get below 60 degrees.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
How do you replace the dispenser funnel on an LG Refridgerator model LRSC-26923
funnel itself squeeze in on sides to release tabs. so many tabs broke a redesign was made 5-30-2005 , have to replace frame bracket and funnell. models after tant had new design. part number from exploded view: 3016JA2002C funnel 278d location number exp. view
3210JA0006S frame 278b location '"" '' ""
Sep 10, 2009 | LG LRSC-26922 Side by Side Refrigerator
Very loud clicking noise from my LG LSC26905TT refridgerator
first you have to remove all shelves in the freezer,then remove all screws in the interior rear panel. In some cases you'll have to remove a couple of shelf tabe located on the side wall. Once tha panel is removed,the fan will be in plain sight. The blade is usually aboue 4-5 inches in diameter and is attached to a small motor with 2 wires and a green grounding wire. Note: you might want to check why it's making noise. Is there ice built up around the blades?Are you getting too much moisture entering the box thru faulty door gaskets?
Aug 26, 2009 | LG LSC26905TT Side by Side Refrigerator
How do you unlock a keypad on an lg refridgerator?
I assume that you means the keypad that controls the different modes for the water/ice dispenser. Press the far right key
Jul 10, 2009 | LG LSC26905 Side by Side Refrigerator
Electronic temperature is locked
it sounds like the main control pcb is bad. it is not letting the defrost cycle work correctly and now the damper in the refridgerator side is stuck
May 06, 2009 | LG LSC26905TT Side by Side Refrigerator
LG LFX25978ST 33 " Wide Ultra Capacity 25cu.ft 3 Door French Door Stainless Steel Refrigerator - LFX25978ST Logo
12 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
