Question about Compaq Computers & Internet
What voltage switch on motherboard compaq presario cq5320y
    Champion:
    Habit-Forming:
  • 245 Answers
What voltage swith ? can you be more specific ?
Posted on Apr 24, 2014
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: Compaq Presario SR1620NX Desktop won't turn on
I may state too detailed, and over simplify in my solution.
This is not to insult your intelligence, but an endeavor to explain thoroughly.
To bypass the Power On switch, one uses a jumper wire to jump the Soft Power On wire, to ANY Ground wire.
The Soft Power On wire has Green insulation, and is located in the 24-pin ATX main power cable.
ANY wire that has Black insulation is a Ground wire.
To explain:
This is HP Support, and the Motherboard Specifications page, for the Compaq Presario SR1610NX desktop computer,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1127350
I would like you to scroll down the page, until you come to the motherboard illustration.
(Under the - Motherboard layout and photos - heading)
This illustration represents the motherboard from a top view, and with no hardware components installed.
(No Processor, Ram Memory modules, power cables from Power Supply plugged in, and so on)
At the top right of the motherboard is a small rectangle, with an inscription in it.
(The tiny printing reads - SMSC with LPC47M997NR under it)
Immediately below this small rectangle, is the 24-pin ATX main power cable connector.
Two vertical rows of 12 socket holes.
(Next to it is printed - ATX 1)
Now here is a much better view of a 24-pin ATX main power cable, and the corresponding connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The photo to the far left, shows a better view of the 24-pin ATX main power cable connector, on the motherboard.
(Yours may be an opaque whitish plastic. It also will not be located on the outside edge of the motherboard)
The photo in the middle, shows the 24-pin ATX main power cable not plugged in.
The photo all the way to the right, shows the 24-pin ATX main power cable plugged in, and shows the Green Soft Power On wire.
Also shows the Black ground wires.
The 24-pin ATX main power cable is left plugged into the motherboard.
Looking at the middle photo once more, note how the power wires come into the connector.
This is the Back of the connector.
Each wire ends in a metal terminal.
The metal terminal is approximately 1/2 inch in length.
This means the power wire goes down in the connector pretty deep, before it ends in the metal terminal at the Front of the connector.
I use a wire that is approximately the same size, (Gauge), as the power wires, for the jumper wire.
Strip around 1/2 inch of insulation, from each end of the jumper wire, then twist the wire ends.
The jumper wire should be around 3 inches in length, and bent into a U-shape.
Power supply unplugged from power, insert one end of the jumper wire into the socket hole that contains the Green wire.
(Soft Power On wire)
The jumper wire end is stuffed down into the socket hole with the Green wire, right next to the Green wire. You are pushing the bare stripped end past the insulation of the Green wire, with the intent of touching the metal terminal end.
Insure that the stripped bare wire, is touching the metal terminal end, as best as you can.
The stripped end may have to be longer than 1/2 inch.
(An alternate form of jumper wire is a paper clip straightened out, then bent into a U-shape, with wraps of tape in the middle for insulation. I have used this method also. I just don't recommend it for solutions)
Power supply plugged back into power:
With the one end stuffed down into the socket hole for the Green wire, hold the jumper wire by the insulation, and touch the other end down into ANY socket hole that has a Black wire. (Ground)
Warning!
There may be a spark. You may wish to wear a glove on the hand for the jumper wire.
The voltage is 5 Volts (DC)
Two common flashlight batteries are 3 Volts. (DC. Each battery produces 1.5 Volts)
To me it isn't a big deal if there is a little spark. Wanted to advise you beforehand, so that you would be aware, though.
The Power On button that you push is made of plastic. Located inside it is the Power On switch.
With finesse the Power On switch can be removed, and a new one inserted.
(I use a hair dyer on low heat setting, and move the hair dryer back, and forth to gently soften the plastic, so that tabs can be eased to one side, and the Power on switch removed.
The Power On button/switch assembly can also be lowered, {Removed from computer}, into a bowl of very, very warm water, to soften the plastic Power On button. The switch will be removed, and thrown away. The plastic Power On button is then dried, and readied for the new Power on switch)
(Barring the worst case scenario, if a correct Power On switch cannot be obtained, a Power On switch can be used by itself, and would just hang outside of the computer. Not very aesthetically appealing, or professional, but the computer will work again)
I have found that this generic Power On switch, seems to be a correct substitute for most computers,
http://www.directron.com/atxswitch.html
Ebay may have one in Computers and Networking>Computer Components.
Older computers, used a different method to turn the Power Supply on.
(PSU - Power Supply Unit)
The Power On button pushed against a long metal rod, which in turn pushed against a Power On switch, located in the Power Supply.
The Power Supply in your computer always has a constant 5 Volt standby power, when the Power Supply is plugged into power.
When the Power On button is pushed, it pushes against the Power On switch.
Inside the switch is a convex shaped thin disk of metal.
The 'plunger' of the switch, pushes against the middle of the convex metal disk.
The outside edges of the disk are connected to Ground.
When the convex disk flattens, the middle touches a Positive connection.
This contact is Momentary.
The Power On switch is a Momentary Contact Switch.
When you let go of the Power On button, the disk resumes it's convex shape, and the brief connection is broken.
The Power On switch wires connect to pins on the motherboard.
The area the pins are in, is the Front Panel header.
(A connector on a motherboard is referred to as a Header. The plastic piece on the front of a computer is a Front Panel. Sometimes referred to as a Front Bezel)
To remove the Front Panel to your computer, far enough to easily access removing the Power On switch, the Power On switch wires will have to be disconnected from the Front Panel header, on the motherboard.
So will all the wires leading from the Front Panel, to the Front Panel header on the motherboard.
Looking back at the motherboard illustration, the Front Panel header is located on the very bottom right of the motherboard.
JFP1
(Junction Front Panel 1)
You will note that there are two rows of pins.
Four across the top row, five across the bottom row.
BEFORE (Not shouting) you attempt to remove the Front Panel, it would behoove you to make a drawing, and notes as to where those wires go.
If wires come loose, I don't have a way at present to tell you where they go.
It has been a while since I have worked on this series of Compaq Presario's. The wires from the Front Panel may just end in a single connector, that you simply line up with the corresponding pins on the motherboard, and plug the connector in. (On?)
The connector is oriented, by the pin in the Front Panel header that is missing.
Four pins across the top, with one missing.
Five pins across the bottom.
The connector will also have one hole blocked off, to match the pin layout of the Front Panel header.
The other wires from the Front Panel though, may not end in a single connector.
These headers are for the audio connections on the Front Panel, USB ports, and so on.
I'll await your diagnoses to see if a new Power On switch is required, or a new Power Supply.
If it is a new Power Supply that is required, I will give recommendations, and why, if you wish.
Should you have any questions, I will try to reply as speedily as possible.
Posted on May 26, 2010
Testimonial: "Thank you so much! What a great reply! I really appreciate the detail, references to online manuals as well as the suggestion for where to get parts. Wonderful help! THANK YOU!!!"
Run a s.m.a.r.t. test ERROR: (on the drive )said ERROR CODE: BIOSHD-8 (WD-WCAWF2969755)wdcwd50000aaks-65voao. I have a Compaq Presario Model# CQ5320Y Installed win. 10 now itwon't reboot
Use a partition eraser on the drive. Note that unless you use a disk like Hirens boot cd and make it an iso and put it on a bootable drive as an image, you are going to have issues with having to remove the drive and connect it to another computer to remove the partition.
Mar 02, 2017 | Compaq Computers & Internet
Why compaq presario SR3270nx won't boot but fan runs?
Hello There "A"
Usually PCs that won't boot its for any of these reasons:
1) Voltage on outlet check this*
2) bad Power Supply.
3) bad RAM
4) any near CPU capacitors, on the motherboard.*
Carl
May 04, 2014 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
I cant turn on my compaq presario f700
Check the fuse in the plug. If this is fine check for an output voltage from the AC adapter usually about 19.5 volts DC. If this is present it is like you have a damaged DC connector on Laptop motherboard.
Aug 20, 2012 | Compaq Presario F767NR Notebook
Winxpsp2 user verify solutoin
Go to the link below and download Ophcrack and burn the iso to a cd. Boot from the CD and let it do it's magic. You'll have your password shortly:
http://ophcrack.sourceforge.net/download.php
Aug 17, 2012 | Compaq Presario CQ5320Y Desktop PC, AMD...
Manual for cq5320y compaq computer
manual to do what.? name something?
most HP products can have over 30 books,guides etc.
did you even look at HP firsts.
cq5320y
the real name is:
its a DESKTOP
this is all there is, on old compaq circa 2009?
still support it is,
https://support.hp.com/us-en/product/compaq-presario-cq5300-desktop-pc-series/4079828/model/4107710/manuals
Dec 24, 2011 | Compaq Computers & Internet
My compaq presario is not switching on.
Could be a number of things, related to the power supply. However if there are any lights on then it is likely to be a motherboard problem. Contact a local PC repair shop. I had a simiar problem and it was the on board video card. They should not charge to diagnose the problem. Mine cost £80 to fix at PCZone, Birchwood.
Feb 24, 2010 | HP Compaq Presario F500 F700 and G6000...
Front power-switch wiring for Presario 5000 Desktop
it will depend on the motherboard you purchase. if i were you I would look up the schematics for that motherboard in google search. or tell me what your planing to buy.
Jan 03, 2010 | Compaq Presario 5000 PC Desktop
Presario f700 no fan/lights = nothing at all. The charger works
Sounds like the power converter. The power input and the battery are single voltage. The computer requires multiple voltages which are generated by a power converter. If you have installed this motherboard, ensure the connections to the power converter are correct.
Jul 02, 2009 | HP Compaq Presario F500 F700 and G6000...
Presario 2199us How to switch IDE HD from
In BIOS boot order; you just switch them.
or
On the motherboard you switch the wires connected to the motherboard.
May 08, 2009 | Compaq Presario 2199us PC Notebook
Power
I hope trouble with your motherboard as far as your power supply is new and giving the accurate voltage.
The motherboard is controlling the switching device. Some short circut may be happening
Jul 20, 2008 | Compaq Presario Notebook
Computers & Internet Logo
22 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
