Question about RCA F32450 32" TV
No power/RCA ctc187cl
Hello, I recently had a brown out and then my rca ctc187cl would not respond. I am an experienced electronics tech and have some tv knowledge. The main fuse was blown, replaced fuse, blew again right away. Voltage regulator seemed to have several shorted pins. Replaced regulator with stk730-150. Fuse is holding now but still no power. I have a V.O.M. and I could dig my Oscope out of the garage but really don't want to have to do that. Do you have any fairly quick and easy Ideas. Thanks!       Doug
When you plug the set in do you here chirp from the set if not power is still not getting to the regulator check components around main ac power supply
Posted on Nov 02, 2007
    Genius:
  • 1,694 Answers
Check for 5 volts present at pins of EEPROM IC. ( 8 pin-center
front) = no 5 volts = Re-check power supply components such as AC in resistor 2.7 Ohm ?....Or 5 volts ok,then suspect EEPROM corrupted........part # 223957 ( install 8-pin socket,then re-plug in original, if that doesn't clear it, plug in
new part) Use pre-programmed after-market replacement,if you
can get it.....Let me know....T.
Posted on Oct 31, 2007
Screen went black sounds of crackling and smell of burning wires
Hello
There is somethin wrong with either its EHT section or power supply section. Your description gives me very little to say a strong opinion. In both cases, it is very dangerous to handle the components at these sections. If you haven't got enough experience in handling high voltage electronic sections, never attempt to do anything with this TV. Normally EHT arcing is more common to this type RCA sets. In my opinion, get it repaired by any experienced service technician. OK.
May 24, 2011 | RCA D52W19 52" Rear Projection Television
We have a LCD Electron TV recently purchased from Walmart and we are trying to find the code to program an RCA universal remote control to work with it, but we are having problems. We tried everything...
Visit the below link, it is a RCA remote code finder.
Enter your RCA remote model, the select TV, then search. This should help in getting the code...
Good luck.
Mar 09, 2011 | RCA Televison & Video
When powered up-TV continually changes channels---RCA P52937SG MFG 2003
look at the control board circuit -are there and signs of heat damage if so replace board
May 02, 2009 | RCA P52937 52" Rear Projection Television
RCA d52w20 TV will not turn on, already replaced flyback & cp150(was blown)
Hello weewilliemom,
Have you tried to see if CP120, CP140, and CP150 are good? These capacitors usually are the cause of the problem you are experiencing. I have a copy of the schematic is you need it.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you have....is this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
My 52' RCA does not want to power on. When I click the power button, sometimes nothing happen. But other times the green light blink 3 times then goes off, but the television still does not want to come...
You need a flyback, please respond to this same post with your model number of your RCA and I will post a link where you can get a new replacement with free tech support so you can easially install it yourself.
Aug 17, 2008 | RCA Televison & Video
Verify that you don't have a stuck channel up button on the panel. Next check the solder connections on the IR receiver (3 pins). Also check the +5 supply for excessive ripple. Any of these can cause odd behavior. Let me know how you make out.
Dan
May 02, 2008 | RCA P52937 52" Rear Projection Television
Distorted image
Thats a strong possibility as the STK730-010 is the power amplifier for the convergence circuits. Its an inexspenive part to replace and easy to install. You can get a replacement IC at the following link and they provide free on line tech support for free as well as send instructions on how to replace the IC. Here is thier link if youd like it. I am one of thier on line tech supports as well as one of thier board rebuilders.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | RCA P52960 52" Rear Projection Television
No Power RCA chassis CTC187CL
Find Capacitor C4127, this is a startup cap and will fail. Then check C4709, C4105[this one almost always goes bad] and C4404. These are good starting points. You will have to resolder the Tuner as it will coorupt your eeprom and can create a dead set. And inspect the pins a Regulater T4101 I beleive, for busted grounds. If this will not start the set you will need a new eeprom or the T4101 Regulator. The regulatore rarely goes bad in this TV!
Mar 18, 2008 | RCA F31672ET TV
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
RCA F32450 32" TV Logo
90 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
