Question about Emerson Audio Players & Recorders
Top does not stay closed - Emerson Audio Players & Recorders
    Champion:
    Habit-Forming:
  • 239 Answers
Catch broke for holding door down?
Posted on Aug 09, 2014
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
When I close the fridge side the freezer side pops open a little and stays open. The appliance is 5 years old. This started very recently
a couple of problems can cause door problems first open door and check seal for damage [popped off trac or rip-tears]other is hinges worn- bent-loose --if seal is good at top and bottom of door are hinges check for loose if loose tighten -if bushing lookes like a little round washer type is broken or missing replace --needs realignment loosen top hinge and close door and adjust till door is straight and stays closed tighten door hinge done good luck
Jun 28, 2011 | Jenn-Air JCD2389G Side by Side...
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Whirlpool ET0MSRXTL00 top freezer that no longer stays cold
Hi, Is there a frost buid up or is the evaporator fan motor running? Let me know andI can help you further.
Vic
May 16, 2009 | Whirlpool ET0WSRXML Top Freezer...
Error message tells me the top is open it isn't,
when the top is opened there is a sensor which comes up and the cartridges come in the center.when the top is closed the sensor gets pressed due to the closed topo and the cartridges move towards in.as the cartridges are coming in between and you say top is closed this indicates that the top lift door sensor is out of position or it is not getting pressed just check out properly the sensor is getting blocked or its broken.
Mar 06, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
RCA DRC83200N DVD Recorder tray won't stay closed
hit the top of the player hard. really, it works.
Dec 15, 2007 | RCA DRC8300N DVD Recorder/VCR
46 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
