Question about Manitowoc Kitchen Appliances - Others
How to install water chilled lines - Manitowoc Kitchen Appliances - Others
    Novelist:
    Champion:
  • Manitowoc Expert
  • 373 Answers
You should have this done by a service company.
Posted on Oct 10, 2014
Water leaking from water filter housing
if water is leaking from where water line is try cutting the very end off water line and reinstall water line... if it is leaking any where else replace housing
Oct 09, 2014 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
No ICE or Chilled water
Colin,
The water line is fine (what about water inside that line). Please check the source of the water line, I am sure when the previous used it they might have shut the water valve somewhere. Check your basement for that small valve etc.
Feb 27, 2014 | Whirlpool Refrigerators
CSCP5UGXSS water temp
Hello dharitos1. I understand you are concerned about the temperature of the water in your refrigerator. Since the line runs through the door, the water will be slightly chilled, but will not be cold. You may need to run the water through a couple of cycles to get the chilled water. This is normal. I hope this information is helpful. Sincerely, Melanie, Whirlpool Social media group.
May 24, 2012 | Whirlpool GS6NBEXR Side by Side...
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker is on but is not producing ice
The ice maker is probably not getting water. Have you heard the water valve click on and off to allow water to flow to the ice maker? If you get chilled water from the fridge, the ice maker's water valve will probably sound very similar to when you dispense chilled water. Try the water to listen for it. Then, listen for it over the course of an hour or so to determine if the ice maker is doing the same thing. If you hear it - then there may be a blockage in the line or filter.
If you don't have provisions to get chilled water from your fridge (ice only) or notice that you can't get water from your fridge any more: Make sure the water supply is on and.. that supply line isn't kinked or got crushed when the fridge was pushed back into position. This is a pretty common occurrence. If you don't hear any water valve clicking, the valve itself may have failed or there may be a problem with the electrical circuit. Hopefully, you won't have to got beyond this, but if so - let us know.
May 24, 2010 | GE GSS25LGM Side by Side Refrigerator
French door model installed yesterday with outside water & ice. the water is not cold from outside dispenser. have freezer set at 0 F and frig at 35 f
theres only so much water that resevoir inside can hold once it empties it must sit to cool or chill. once used then ur just gettin straight water from ur water line from the house...
Jan 28, 2010 | Electrolux Refrigerators
Ice make lines. What is the white long(25 ft) in
It is the chilled water resevior, so that when you get water from the dispenser it is chilled and not room temp.
Apr 19, 2009 | Frigidaire FRS6HR5J Side by Side...
I would like to know something.I have a big plastic corel in the back of the crisper pan and I do not know where it go.I have a plastic tube which go from the water valve inlet to the drinking water line...
The coil of plastic tubing behind the crisper is your chilled water reservoir for the water dispenser. They use a coil instead of a tank because it chills the water more quickly and ensures good turnover of the water with less chance of stagnation.
Jul 27, 2008 | Frigidaire Refrigerators
Water line
That coil is the line to the water dispenser, and its purpose is to chill the water before dispensing it. The coil of tubing is better than a tank because it chills quickly, takes less space and doesn't hold stagnant water. It shouldn't have any effect on the icemaker.
Jul 26, 2008 | GALAXY Microsystems 25.4 cu. ft....
Kitchen Appliances - Others Logo
103 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
mike cooper
Dan Webster
Dan Webster
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
