Question about Toys
Bobcat s220 engine removal
Engine. Remove. Procedure
motor1258
  • 6674 Answers
SOURCE: need procedure to remove/replace radiator on 01 Dodge Grand Carva
This Link is for R&R rad fan assy, but once your there, the rad should be pretty obvious, what else needs to be done. Fan has to come off first anyway.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528021e5b1
Posted on Mar 01, 2009
lastech
  • 408 Answers
SOURCE: Radiator removal procedure Mercedes 1992 190 E 2.6L Engine Auto
hi,you can do it,open the hood,remove 2pcs. of steel clip for radiator,2 pcs. for shroud,look for connection of oil cooler remove also,then lower and upper hose,you can lift your radiator,ty
Posted on Apr 05, 2009
TampaNative
  • 778 Answers
SOURCE: NM Pajero 6G7 engine auto tensioner removal
You'll need to remove/loosen one of the components (such as the alternator or power steering pump) to relieve tension on the belt before removing the tensioner as it should be spring loaded. Installation is going to be the reverse of the removal procedure.
Also, if the tensioner is noisy, replace it.
Posted on Sep 03, 2009
  • 743 Answers
SOURCE: how do i remove the head from my saturn 1.9 engine?
Removing it isn't too hard, replacing it is another story. Drain antifreeze. The top radiator hose will need to be taken loose. Air intake from front of car to filter.The fuel lines...You just need to pinch the plastic clips with a pair of needle nose pliers while you pull on the lines.The timing chain will need to come off,make sure the marks are at top dead center, bottom and top sprocket. You will need to take off the EGR valve, The vacuum lines on top of the throttle body. Vacuum line under Air intake. Throttle cable, manifold exhaust, 02 sensor, A/C compressor if you have one, just lay it aside...doesn't need to be discharged. Power steering pump need to take the bolts out of it by turning the sprocket so you can get a deep dwell socket in it...about 3 or 4 bolts there. The tension pulley needs to be taken off, of course after the belt is taken off. A few other things that are obvious by looking. Most importantly, have the head tested before putting on new gasket. The bolts should all be replace on the head since they are torque to yield. The torque procedure is 25lbs, all then 35lbs. all then turn the wrench on all of the bolts from 12 o'clock to 3 o'clock which equals 90 degrees. That will give you the torque to yield...
Posted on Oct 18, 2009
SOURCE: what is the procedure for
Click on the link below to view detailed instruction on how to remove and replace the radiator in your 1995 Olds Aurora.
http://www.ehow.com/how_4809689_remove-a-radiator.html
Posted on Sep 14, 2010
I have a 943 Bobcat skid steer. Where do I get a block heater for it & how do I install it?
You can order it from any auto parts store, it goes in the engine block, you must remove one of the core cleanout plugs AKA freeze plugs.
Nov 21, 2016 | Toys
Cts03 3.2 What's the best way to get to starter?
Jack the vehicle up an crawl underneath on the passenger side ! Don't forget to disconnect the negative battery cable .
Removal Procedure
  1. Remove the starter heat shield. Refer to Starter Shield Replacement .
  2. Remove the right side engine mount bracket. Refer to Engine Mount Bracket Replacement - Right Side .
Removal Procedure
  1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  2. Remove the right catalytic converter. Refer to Catalytic Converter Replacement - Right Side in Engine Exhaust.
  3. Remove the starter motor heat shield. Refer to Starter Shield Replacement in Engine Electrical.
  4. Install a screw jack with a block of wood under the oil pan for support.
    showgif.do?image=816388
  6. Remove the right engine mount upper retaining nut.
A lot of work !!!!!! Taking to a qualified repair shop mite be worth it .
Labor $174 - $222
Sep 19, 2016 | Cadillac CTS Cars & Trucks
The adjustable seat guides are rusted on my bobcat 553. How can I remove the seat to fix the adjustment?
remove the whole seat assembly
tip upside down and remove the retainers from the slides and pull the seat of the slides
get new seat slides and reverse the assembly procedure
Jul 19, 2016 | Seat Cars & Trucks
Replacing oil pan gasket 1998 chevy silverado 305 cu.in.
REMOVAL PROCEDURE
  1. Remove the oil level indicator tube.
  2. Raise the vehicle.
  3. Remove the engine oil and the engine oil filter.
  4. Remove the oil filter adapter.
  5. Remove the starter.
  6. Remove the flywheel inspection cover.
  7. Remove the engine mount through bolts.
  8. Raise and support the engine.
  1. Remove the oil pan nuts and bolts. Note the location of any studs to assist reassembly.
  2. Remove the engine oil pan and the gasket.
  3. Clean all sealing surfaces. Refer to Oil Pan Clean and Inspect under Engine Unit Repair.
INSTALLATION PROCEDURE
  1. Install the engine oil pan and a NEW gasket. Refer to Oil Pan Installation under Engine Unit Repair.
  2. Lower the engine onto the mounts.
  3. Install the engine mount through-bolts.
  4. Install the starter.
  5. Install the flywheel inspection cover.
  6. Install the engine oil filter and the engine oil.
  7. Install the oil filter adapter.
  8. Install the oil level indicator tube.
May 04, 2015 | 1998 Chevrolet Chevrolet silverado
How to put distributor in a wisconsin v-4 fan cool engine?
Go to number one piston and remove plug. Put finger over hole while tapping starter. When pressure(air) comes out of cylinder put piston to the top. Put distributor into position with the rotor pointing to number one . Re install spark plug and hook up all four wires. 1-4-2-3? not sure of firing order. Start and run engine.
Adjust distributor to highest idle RPM, w/o kickback when starting.
Jun 15, 2014 | Bobcat Equipment Skid Steer Flatbed...
What is the easiest way to remove the fuel tank in a bobcat 853
There is no easy way, other than removing engine as the tank is wedge shaped and lies under engine and battery.
In a pinch get a boat fuel tank and re route your fuel lines.
Dec 18, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Replace rear wheel bearing 773 bobcat
you must unbolt it from inside chainbox. Raise cab, and remove about 8 bolts that hold a plate that is back toward the engine, in line with back axle. Inside you will see 2 large chains and sprockets, and a bolt that holds the sprocket to axle. Use a 1-1/8" wrench to remove bolt, then axle may be removed. Replacing outer bearing and seal is now possible
Sep 23, 2012 | Bobcat 773
How to replace drive belt on a 610 bobcat
When replacing the drive belt on a rear-drive lawn mower, make sure the spark plug is disconnected, remove the blade, take off any bolts for the belt cover and remove the belt. Find out how to put a drive belt on the engine pulley with help from the owner of a small engine repair shop in this free video on lawn mower repair
Audi Performance Chip
Jun 19, 2012 | Audio Players & Recorders
Want to know how to change a thermostat on my 2004
It Depends on which engine you have, this is how it goes for both. I use a little RTV with a new ring as well.
THERMOSTAT REPLACEMENT (4.2L ENGINE)
Removal Procedure
1. Remove the necessary coolant from the radiator.
2. Remove the generator.
3. Loosen the outlet hose clamp at the thermostat housing. Remove the outlet hose from the thermostat housing.
4. Remove the thermostat housing bolts.
5. Remove the thermostat housing from the engine block.
6. Clean all of the surfaces of the thermostat housing.
7. Clean the sealing surface of the engine block.
Installation Procedure
1. Install the thermostat housing to the engine block.
2. Install the thermostat housing bolts.
Tighten: Tighten the bolts to 10 N.m (89 lb in).
3. Lubricate the inner diameter of the radiator hose with engine coolant.
4. Install the outlet hose to the thermostat housing. Secure the hose with the clamp.
5. Install the generator.
6. Fill the cooling system with specified coolant and concentration. Follow the correct cooling systen bleed procedure for your engine.
7. Inspect all sealing surfaces for leaks after starting the engine.
THERMOSTAT REPLACEMENT (5.3L ENGINE)
1. Drain Radiator and remove the radiator outlet hose.
2. Remove the water pump inlet bolts.
3. Remove the water pump inlet and thermostat from the water pump.
IMPORTANT: The thermostat is not serviceable separately. The water pump inlet and thermostat must be replaced as an assembly.
1. Install the thermostat and thermostat housing to the water pump.
2. Install the thermostat housing bolts.15 N.m
3. Install the radiator outlet hose.
4. Fill the cooling system with specified coolant and concentration. Follow the correct cooling systen bleed procedure for your engine.
5. Inspect all sealing surfaces for leaks after starting the engine.
Mar 17, 2010 | 2004 GMC Envoy
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
