Question about 325i Repair kit lock cylinder left. Door handle front/lock/key
BMW Z3 door lock repair kit
On the driver and passenger door, the door key lock just spins when you put the key in the tumbler. So you cannot lock or unlock from door. How do you fix the tumbler on a BMW Z3 roaster door lock?
  • 3 Answers
SOURCE: BMW Z3 SPORTS CAR 1998
its the dreaded seat rock syndrome, plenty of fixes on the forums, basically you have to replace spacers in set drive mechanism. I did with the help of a friend after ordring bushes and it was quite easy.
Posted on Nov 28, 2008
SOURCE: 2002 BMW 325 - key locked in trunk
There are several suggestions out there on how to retrieve BMW keys from the trunk. Many of the ways I tried failed, and it takes 2 to 3 days to get a new key made up. In the coupe there is the center piece in the back seat that folds down. Then on the back wall there is material that will fold down that is held up with Velcro. Behind that you will find a rubber insulation that is mostly cut and looks like a door, but not all the way. Carefully cut the rubber to remove the piece. Now you will find a metal wall, but there is a large piece that is tack welded on. I got turned around and kicked it with the bottom of my foot and got 3 sides loose. Then a softball bat knocked the final side loose. Pull that out and trash it, the final barrier is the insulation that is held in place with plastic clips that can just be pushed down. After that you can a pretty large hole to work through and get the keys. Just put everything back in place other than the metal plate and you will never know anything was done.
Posted on Mar 30, 2009
  • 51 Answers
SOURCE: BMW Power Locks don't work, how much to repair?
Before you bring it to a garage and pay good money check the fuses. Usually its as simple as that (located near the battery in the engine bay)
Hope this helps.
Posted on Apr 30, 2009
  • 4 Answers
SOURCE: 1995 BMW 318i: Key does not turn in drivers door
you probly have a siezed lock pin, or the metal flap that stops debris from gettin in the lock is stuck. if you can see inside your lock, then get some WD40, and some lock de-icer, spray the lock with the WD40, and try to put your key in, it should go in. If it doesn't go in, and more backyard style way would be to get a thin piece of metal that will fit in the slot try to gently move it up and down prying on the top and bottom inside the lock. use the metal trick at your own risk, for it may cause damage, i don't recomend it, the Wd40 should work spray it, let it sit for 5 mins, spray it and then try it.
Posted on Jun 13, 2009
SOURCE: 1997 bmw 328i ignition lock
There is nothing wrong with the lock,,,it is suppose 2 spin around if you do not put the key in correctly.
My 1997 bmw does the same , it is a security measure incase someone breaks into the car and tries 2 steal it by putting a screwdriver in the ignition ,,it just spins.
before putting yr key in the ignition, move yr steering wheel slighty so its not resting on the steering lock , put yr key in and turn , it does not spin
Posted on Sep 20, 2010
I have a 2004 Honda Civic LX Sedan. My problem with it is one, where you put the in to unlock the car,driver side, won't turn. I know the problem is the key lock cylinder itself, one of the tumblers wont...
To fix the tumblers, find a trusted locksmith. That's the way I'd go. Honda does have a kit, but, it's not a consumer one. You'd spend a decent amount of money on a kit that would fix hundreds of cars, so, that's why they won't sell it to you.
As for the key fob, have you tried putting a new battery in it? Your description is not very clear. The LX should have come from the factory with a key fob. So, if you got one, make sure it's the correct one with a good battery. To program it, put your key in the igntion, turn the key to position 2 (the position right before you start the car), press a button on the key fob, turn the key back to position 0, Repeat these steps over and over (about 4 to 5 times) until the doors lock/unlock. If that doesn't work, you could have a bum transmitter.
If some doors are not lock/unlocking, chances are bad doorlock acuators.
Sep 12, 2013 | 2004 Honda Civic
Hi all, the central locking on my bmw z3 does not seem to work this morning. Both door locks accept the key with force although do not seem to turn - Stiff, akward movement within the lock. The boot lock...
First try lubricating locks with powdered graphite. Avoid ALL liquid lock lubricants. Then work locks through all positions from passenger door. (single lock positions & double lock position) Lastly operate locks via boot lock.
Mar 14, 2011 | 1998 BMW Z3 Roadster
1997 bmw 328i ignition lock just spins around, i need the tumbler fixed. are there other bmw years that are interchangeable? I don't mind using two keys, one for ignition or one for doors. I don't care...
Sep 14, 2010 | 1997 BMW 328
1996 BMW Z3 trunk wont open with key
It may be that the rod from the lock tumbler to the latch may have come loose.
Mar 02, 2010 | 1996 BMW Z3 Roadster
Driver and passenger door locks will not open with key
you can buy a new, complete lock set on ebay from EMGEE store for about $25. The tumblers are worn.
go here too
http://groups.yahoo.com/group/villagerquest/
Nov 30, 2009 | 1995 Mercury Villager
I locked my wifes Z3 with the key when I washed it and now the passenger door will not open with the remote or the door handle,have I put the system out of sinc
i think so. disconnect battery first, put keys in ignition and turn to the point before firing up would be, refit the battery earth. Should now be able to res ync fob and get door open
Oct 07, 2009 | 1998 BMW Z3 Roadster
Door wont unlock when i put key in
I believe your problem is directly related to the elecrical contacts in the door key lock itself. I understand that the door locks but wont unlock. If the switch in the lock tumbler it self is not defective you may have other electrical problems in this circuit. do you have the same problem on the passenger door or is it specific to the drivers side only
Oct 07, 2009 | 1999 Ford Ranger SuperCab
98 camry door lock will not turn....
really sounds like the tumbler pins are stuck in the cylinder of the lock. mite want to spray some lubricant like(PB Blaster)or WD-40 in the cylinder key hole and push key in and out to see if tumblers will release..gd luck..chris
May 12, 2009 | 1998 Toyota Camry
Jun 03, 2008 | 1998 BMW Z3 Roadster
325i Repair kit lock cylinder left. Door handle front/lock/key Logo
94 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
