Question about Kenmore 24032\24036 Top Load Washer
Machine will not go into the "slow speed" Sears Kenmore
Machine operates in all modes except the slower speed does not work, machine operates at the higher speed through all cycles.
3 year old Sears Kenmore 110.26422500. Direct drive motor.
I have checked the motor connections for good contact.
It seems to be impossible to get to the timer control on this model.
Any suggestions?
  • 15,935 Answers
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
Sears kenmore sewing machine model 148-13100 running slow
Did you open the top of the machine and oil every place where metal rubs against metal? Did you do the same under the machine? Use only GOOD quality sewing machine oil. If the machine is slow to recover (it may take a while for the oil to sink in), you can direct hot air from a handheld hairdryer into the internal mechanics. AVOID trying to run the machine until it moves freely or possibly risk damaging the motor.
Apr 23, 2017 | Kenmore Sewing Machines
Water run in slow
Check the valves on the hoses, Take the hoses off the machine and see if there are screens inside the connections on the washer. If so clean them, Depending on the amount of minerals in water, you may have build up on the valves or the fill tubes, you may also have low voltage on the valve solenoids and last by not least, check the water pressure on the house.
Jul 25, 2014 | Kenmore Washing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Sewing slows after use
The manual: http://www.singerco.com/uploads/download/446_5040_5050.pdf
Jan 08, 2012 | Singer 5050 Mechanical Sewing Machine
I am getting error 244 when receiving a fax.
errors 243 and 244. Taken from HP.
The user of the remote machine has pressed that machine's Stop key causing the session to be prematurely terminated. Alternatively: the remote fax machine determined there was a feature incompatibility between the two machines and has terminated the session. An example would be when the local machine wanted to initiate polling, but the remote machine did not support this mode of operation.
Solution:
1. Confirm the remote user is not inadvertently attempting to poll transmit from the local machine, instead of transmitting to the local machine. This mode of operation must be specially configured on the local machine. If poll transmission from the local machine is the desired mode of operation, confirm the local machine has been configured for this operation.
2. Reconfigure the local fax machine to use different configuration settings, toggle the ECM state and/or select a slower reception speed
Sep 20, 2010 | HP 910 Plain Paper Inkjet Fax
I'm getting an error 244 or 223 when receiving a fax. the fax only partially prints out
Error 244:
Definitions
  • The user of the remote machine pressed the Stop key, causing the session to be prematurely terminated.
  • The remote fax machine determined that there was a feature incompatibility between the two machines and terminated the session. For example, the local machine wanted to initiate polling, but the remote machine did not support this mode of operation.
Solutions
  • Make sure that the remote machine can accept and use polling.
  • Select a slower reception speed.
Error 223:
Definition
The local machine was unable to receive an entire page even after multiple attempts to receive the parts of the page that contain errors. This situation is usually due to extremely poor line conditions.
Solutions
  • Try to receive the fax at a different time when telephone line conditions have improved
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Just purchased a Kenmore 19106 Sewing Machine for my daughter's 16th birthday. It's her first one and she was excited to get it. I don't know anything about sewing machines and how they operate. My...
Take it back. This should not be happening.
If you can, bump up a model.
You can find reviews of sewing machines at patternreview.com - note how long the reviewer has used the machine before they wrote the review.
Feb 20, 2010 | Kenmore Sewing Machines
In spinning mode inside tub hits outside tub of washing machine of Kenmore .70 series, two speed automotic washer.
hi,
thats a 35 year old washer. we had one for years. the springs have lost their tension. youll have to run smaller loads, you can try sears parts direct for springs but they may not have them. It may be time to retire it. keep it for a backup in case you new one has a problem..
jm
Jan 06, 2010 | Kenmore Washing Machines
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
