Question about KitchenAid KAWS850L Top Load Washer
Remove agitator from Whirlpool Washer - KitchenAid KAWS850L Top Load Washer
How to remove the agitator
Washer Agitator Repair Agitator Not Working ... - YouTube
? 7:51
www.youtube.com/watch?v=yxfDICZ0Ses
Apr 21, 2010 - Uploaded by applianceassistant Washer Agitator Repair Agitator Not Working Repair ... of a whirlpool built washer, manufactured under the appliance brandsMaytag, Amana, ... How To Repair Washing Machine Agitator -Remove And Replace Agitator Dogs ..
Sep 14, 2015 | Washing Machines
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool washer, the agitator is not working
    agitator dogs are bad they are located under the agitator you will have to take a 3/8 nut driver and remove the center screw in the agitator to get to the pull up own the agitator and they are located inside of there.
    Dec 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    How do I replace the CAM-AGIT on a Whirlpool Washer Model #395165
    you have to remove the cover inside the upper agitator first, then you will see a plastic cover inside the top. it has 2 raised handle type tabs to pull on, then remove the cover and under it you will find a 7/16 bolt to remove and that will allow you to pull the tophalf of the agitator and change the agitate" dogs "
    Dec 31, 2009 | Washing Machines
    How to remove agitator cam from the upper part of the agitator?
    Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
    Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
    My washing machine spins but does not aggitate what do i need to do?
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
    First, see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number and you'll see a list of major sub-components with diagrams and parts.
    Also see the Whirlpool / Kenmore installation and operations manual for top load direct drive washers.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    Also look at the Whirlpool parts list for top load direct drive commercial washers (the consumer model is basically the same.)
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
    The Whirlpool / Kenmore top load direct drive washer uses an agitate shaft from the transmission with splines on its' top that fit into slots in the agitator. If the slots in the agitator are damaged / worn, the washer may not agitate.
    Remove the fabric softener dispenser, remove the top agitator cap (a short screwdriver works well), and you'll see a 1/2" square drive bolt. Use a 1/2" socket extension to remove the bolt, pull up on the top agitator and carefully turn it over. You should see four plastic "dogs" that allow the top agitator to turn one way only. If they are worn, they are easily replaced.
    After removing the top agitator, you should see a bolt (I think it's 5/8").
    Carefully remove the bolt and the rubber washer under it and the main agitator should come off. You'll see the top of the transmission agitator shaft with it's splines. Check them and the slots inside the main agitator.
    If the splines on the transmission agitator and main agitator are OK, the washer spins and drains and the timer moves through its' cycle, the problem points to an agitate gear in the transmission itself.
    See the parts PDF for the transmission.
    Replacing the gear in the transmission is a bit complicated (and messy) but it's a lot less expensive than a $170 transmission.
    If you decide that you want to work on the transmission (it's not really that hard) post another question on Fixya and I or someone else should be able to walk you through it.
    Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
    How do i remove the agitator on my whirlpool ultimate care II top loader washer
    first you remove the cap on top of the agitator then you remove the inner cap then you use a long extension with a 7/16 socket to remove the bolt the agitator will pull right up
    Sep 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    Clothes mover of whirlpool top-loading washer is loose. Agitates.
    You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
    Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
    Remove agitator on a whirlpool ultimate care II washer
    have you look at the center of the agitator? after you remove the dispenser.
    there i s a bolt there that you have to remove before pulling the agitator at the top.
    tnx 4 using fixya,
    drcool
    Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    KitchenAid KAWS850L Top Load Washer Logo
    Top KitchenAid Washing Machines Experts
    kj henriksen
    kj henriksen
    gbob59
    Mike
    Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
