Question about Homelite Garden
Carberator want idle - Homelite Garden
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Needs cleaning.
Posted on Jul 22, 2014
My Suzuki gs550l idles too low. How do I adjust the idle?
Hi Austin look for a metal knob between the middle carberator's turn it clockwise to raise the idle speed. Regards Jim...
May 03, 2015 | Suzuki Motorcycles
Polaris Scrambler won't idle when moving
If a tune up doesn't help, rebuild the carb. the ethanol in gas ruins the gaskets.
Sep 08, 2014 | ATVs
I have a 2001 yamaha warrior that backfires out the carberator
possible timing issue or sloppy timing chain.
Apr 13, 2014 | ATVs
2007 Vespa 200L Has Been sitting and now will start but wont idle ??
If you left the bike siting for a bit especially with fuel in the tank then that is more then likely your problem. Try new fuel first if that in and by itself doesnt work then you probably have varnishing in the carberator you could try running some carb cleaner through it but if that doesnt do it you will probably need to have the carberator serviced.
Jun 21, 2011 | 2007 Vespa Granturismo
Mtd 22" low idling how do I correct the problem?
if this has a briggs & stratton engine on it, then the idling is set thru a spring on top of the carberator. some units have an idle set screw also. if it has an idle set screw, turn it in untill it idles where you want it to, if it just has a spring, then replace the spring.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
New carberater and a mechanic needed!
Even if you do it yourself you need to adjust it.I would get another mechanic to look at it also.Have you tried cleaners? 1 type you add to the gas the other you remove the air bonet and spray into the top of carb while running (have someone press on the gas lightly so you don't stall.Have you tried to increase the idle via the adjusting screw? has the auto choke been tested..adjusted? Good Luck.
Sep 17, 2009 | 1984 Honda Prelude
Miller bobcat 250 welder with kohler lp gas engine won't idle properly any adjustments for air/fuel mix?
Make sure that the idle is set at 40Hz. You do this by placing a frequncy meter on one of the 120Vac outlets. If frequency is low, the engine will run rough at idle. There is a 3/8 nut next to carberator that needs to be turned to the right to increase the idle speed.
May 13, 2009 | Miller Welding Tools
Idles too high
Did you get my solution? regards, p27@tele2.fr
Apr 21, 2009 | Triumph Tr 7 Cars & Trucks
Harley engine wont idle
Your bike has an idle screw on the carb. looking at carb its on the right side turn to the right to bring up your idle.
Mar 24, 2009 | 2000 Harley Davidson FLSTC Heritage...
Need carberator settings for a sears craftsman chainsaw model#358.354831
You don't want to tighten them down just turn them in until the are just snug and then turn them out.
Start with the low at 2 full turns out and the high at about 1 full turn out. Start the saw and let it idle adjust the low idle to where it runs smooth. Adjust the high until the saw runs as much rpm as you can get at w.o.t. (Wide Open Throttle).
Jul 11, 2008 | Electrical Supplies
Garden Logo
20 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
